backb0ne86
uart reception issue on PIC16LF88 |
Posted: Sun Apr 28, 2013 10:09 am |
Hello Guys,
I m having trouble using the PIC16LF88.
Sending is working perfectly fine.
Reception is working only using SW UART (let me think that my board is good). However i want to use the HW uart to use the RDA interrupt.
Reception does not work (kbhit or interrupt).
My compiler is version 4.068.
I have read many think about UART problem, but i did not find the good tips to fix my problem.
Thanks in advance for your help
Here is my code:
#include <16F88.h>
#device adc=8
#FUSES INTRC_IO
#FUSES NOBROWNOUT
#use delay(clock=8000000)
#use standard_io(A)
#use rs232(baud=1200, xmit=PIN_B5, rcv=PIN_B2, STREAM=XBEE, ERRORS)//, FORCE_SW)//, DISABLE_INTS)
char receivedChar;
char receivedCharOld;
#INT_RDA
void rda_isr()
receivedChar =fgetc(XBEE);
fputc(receivedChar,XBEE);
int test;
int c;
char RCSTAValude;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_2(T2_DIV_BY_1,0,1);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_TIMER1);
setup_counters(RTCC_INTERNAL,RTCC_8_BIT|RTCC_DIV_256); // 50hz with preload
set_tris_a(0b00000000);
set_tris_b(0b00000000);
setup_timer_2(T2_DIV_BY_1, 125, 1);
delay_ms(2000);
test=0;
fprintf(XBEE,"Ready");
enable_interrupts(INT_RDA);
do
int test;
int c;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_vref(FALSE);
setup_vref(FALSE);
delay_ms(2000);
//setup_uart(1200, XBEE);
do
//if(kbhit(XBEE))
// receivedChar=fgetc(XBEE);
if(receivedChar!=receivedCharOld)
receivedCharOld=receivedChar;
//Processing
}while(1);
Posted: Sun Apr 28, 2013 1:40 pm |
Start by posting a small compilable program.
What you have posted is half each of two separate programs, and hasn't got a hope of compiling, let alone working. |
Posted: Sun Apr 28, 2013 2:53 pm |
Also, You are using Standard I/O so you don't need to set TRIS.
The below two lines are setting all the pins to outputs.
Get rid of these lines..
Quote: | set_tris_a(0b00000000);
set_tris_b(0b00000000); |
You also enabled Interrupts for Timer 2 with no interrupt handler defined.
Never enable interrupts without an Interrupt handler. _________________ Google and Forum Search are some of your best tools!!!! |
Posted: Sun Apr 28, 2013 9:56 pm |
Also your program has many unnecessary lines which turn off modules
which are already off when the PIC is reset. Normally adding all these
extra lines doesn't cause a problem, but in this case it does:
Quote: |
char RCSTAValude;
setup_adc(ADC_OFF);
setup_spi(FALSE);
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=29830 |
backb0ne86
Posted: Thu May 02, 2013 9:30 am |
Thanks PCM programmer. You are a genius!
I have also corrected my set_tris_b line which was wrong too.
Thanks again all for your usefull replies! |
