pleditor
Char Identifier in a Function |
Posted: Wed Feb 27, 2013 1:26 am |
Cant get this code to work :-/ "attempt to create a pointer to a constant" error
void led(char[4] color)
if (color[0] == 'g') ledA(1,1);
if (color[0] == 'b') ledA(1,2);
if (color[0] == 'r') ledA(1,3); //reading only the first digit (r)
main()
led("r00");
This code works perfect
void led()
char color[4] = "r00";
main()
led();
Mike Walne
Posted: Wed Feb 27, 2013 2:44 am |
Post SHORT complete compilable code which illustrates your problem.
Then we can try it.
Mike |
Posted: Wed Feb 27, 2013 3:42 am |
This is down to the difference in constant strings.
A search in the forum will find a lot about this, and full explanations
Key is that the PIC, does not have a classic memory architecture, with a single 'flat' memory space, containing both ROM and RAM. The ROM is actually in a different memory map to the RAM. Now this has the advantage that the chip can be accessing both memories 'at once', pre-fetching the next instruction from ROM, while working with the RAM at the same time, without having to have cache memory. When you call:
led("r00");
"r00", is _not_ a char string in RAM. You are declaring a ROM string. This is in the second memory space, and on older PIC's,this memory space is completely inaccessible. Hence the compiler has to generate a _program_ which can be called with a value saying 'which character is wanted, not a string that can actually be accessed as an array.....
On later chips this can be programmed round. The compiler command:
#device PASS_STRINGS=IN_RAM
will tell the compiler to automatically copy ROM strings into RAM so they can be normally accessed as arrays.
The forum search will explain what happens otherwise.
pleditor
Posted: Wed Feb 27, 2013 10:24 am |
Ttelmah wrote: | This is down to the difference in constant strings.
led("r00");
wow, thanks for the explanation. I am working with the pic16F887, as soon i get the chance i will try to get this solved. |
pleditor
Posted: Thu Feb 28, 2013 4:08 pm |
i did add the line "#device PASS_STRINGS=IN_RAM" and everything works as expected. Thanks again :-) |
