Fabri
one firmware in two different pic |
Posted: Tue Feb 26, 2013 12:46 am |
Hi to all,
I have one firmware to load with bootloader in PIC18F4525 and PIC18F46K22. Configuration bit are already programmed based on PIC used. Is there possibility to check PIC by firmware and change some configuration by firmware ?
Thanks and Regards,
Fabri |
Posted: Tue Feb 26, 2013 5:14 am |
Yes, the bootloader can manipulate the configuration data. |
Posted: Tue Feb 26, 2013 5:35 am |
However, consider just having the bootloader _not_ use the configuration data at all.
Remember that most changes here will stop the bootloader from working. Anything that affects the clock rate, protection etc. etc..
Have it just ignore any data in this range.
Fabri
Posted: Tue Feb 26, 2013 7:48 am |
Thanks for reply,
I'm not interest to manipulate configuration because already programmed. Anyway I need my runtime firmware can configure some option based on pic used. Can I detect, by firmware, PIC code set different option ?
Thanks,
Fabrizio |
Posted: Tue Feb 26, 2013 11:59 am |
It's in fact better not to write to configuration bits. Your post has been unclear in this point.
You can however readout the DEVID words and make your firmware act specifically on it. |
Fabri
Posted: Tue Feb 26, 2013 2:16 pm |
As I told I don't want write configuration bits.
I'll read device ID as you suggest.
Regards,
Fabrizio |
