Interfacing MRF24J40MA with PIC ??
Goto page 1, 2  Next
jjacob
PostPosted: Sat Mar 14, 2009 4:45 am     Reply with quote
Hi all.
I'm trying to make a wireless sensor network.
So i'll have a PIC, connect the sensor to the ADC, then use SPI to 'talk' to the "MRF24J40MA".
My problem, is that i don't understand how do i configure and control the "MRF24J40MA".
In Microchip site i found : http://ww1.microchip.com/downloads/en/AppNotes/01192a.pdf and of course the datasheet : http://ww1.microchip.com/downloads/en/DeviceDoc/70329a.pdf
Can anybody help me ? Just a little thing for me to start ?
Thank you in advance.
Jacob
PostPosted: Sat Mar 14, 2009 10:57 pm     Reply with quote
That's the data sheet for the module. It says to look at the data sheet
for the MRF24J40 chip, to learn about the SPI interface:
http://ww1.microchip.com/downloads/en/DeviceDoc/39776b.pdf
Look in this section on page 15:
4.0 SERIAL PERIPHERAL INTERFACE (SPI)
4.1 Overview
It tells you that it uses SPI mode 0. Here are the constants for the SPI
modes. You can use the appropriate one in your setup_spi() statement.
Put these statements near the top of your MRF24J40 driver file.
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
Next, you need to know the maximum SPI clock frequency that can be
used. The data sheet doesn't explictly say, but on page 45 it gives the
high and low times for SCK as 50 ns min. So, the clock period would
be 100 ns min, which would be 10 MHz max for SCK. Refer to this figure:
FIGURE 10-1: EXAMPLE SPI SLAVE MODE TIMING
You didn't say what the oscillator speed of your PIC is (or what PIC you're
using), so let's assume it's 20 MHz. You could use a divisor of 4, which
would give you an SCK frequency of 5 MHz.
Given all this information, you can now write the setup_spi() statement:
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4);
The next thing you need to do is write the low level routines which read
and write to the MRF24J40 via the SPI interface.
On page 16 of the data sheet, they have these sections:
4.2.2 WRITING SHORT ADDRESS REGISTERS
FIGURE 4-3: SHORT ADDRESS READ
EXAMPLE 4-1: SHORT ADDRESS READ EXAMPLE
They give some C source code. We need to write a CCS version of it.
Here is their Example 4-1 code:
void SetShortRAMAddress(BYTE address, BYTE value)
CSn = 0;
SPIPut(((address<<1)&0b01111111)|0x01);
SPIPut(value);
CSn = 1;
Here is the CCS version of it:
#define MRF24J40_CS   PIN_C0
void SetShortRAMAddress(int8 address, int8 value)
output_low(MRF24J40_CS);
spi_write(((address<<1) & 0b01111111) | 0x01);
spi_write(value);
output_high(MRF24J40_CS);
I have chosen Pin C0 for the \CS signal. It's presumably a spare i/o pin
on your PIC.
Now let's do the next routine in the MRF24J40 data sheet, which is
this one:
4.3.1 READING LONG ADDRESS REGISTERS
EXAMPLE 4-3: LONG ADDRESS READ EXAMPLE
Here is their sample code:
BYTE GetLongRAMAddress(WORD address)
BYTE toReturn;
CSn = 0;
SPIPut(((address>>3)&0b01111111)|0x80);
SPIPut(((address<<5)&0b11100000));
toReturn = SPIGet();
CSn = 1;
return toReturn;
int8 GetLongRAMAddress(int16 address)
int8 toReturn;
spi_write(((address>>3) & 0b01111111) | 0x80);
spi_write(((address<<5) & 0b11100000));
toReturn = spi_read(0);  // 0 parameter needed to make SCK
return(toReturn);
With this information, you should be able to write these remaining routines:
4.3.2 WRITING LONG ADDRESS REGISTERS
EXAMPLE 6-1: INITIALIZING THE MRF24J40
They don't show it in their code, but at the start of the init routine,
you should:
-- Set the MRF24J40_CS signal to a high level.
-- Set the MRF24J40_RESET signal to a high level.
-- Call the setup_spi() function, as given above.
At the beginning of their sample init routine, they do two software delay
loops. They don't tell you how long these are. Worst case, they might
be using a 4 MHz PIC oscillator frequency, so each loop iteration might be
10 us. So their delay loops might be 3 ms each. If you substitute the
following CCS code for each of those delay loops, I think it would
certainly be safe:
delay_ms(10);
jjacob
PostPosted: Sun Mar 15, 2009 9:41 am     Reply with quote
Thank you PCM programmer.
You gave me TOP LEVEL information Very Happy
And you were also VERY specific in your answer...
With this help i think that i can do the work, and now i understood my mistake Sad
I had some problems relating the pages and the URL of the datasheet that you gave : http://ww1.microchip.com/downloads/en/DeviceDoc/39776b.pdf
Then i search and found : http://ww1.microchip.com/downloads/en/DeviceDoc/39776a.pdf
Now almost all the pages are OK. What was the file that you used ?
The important thing is that with your help i understood how things work with the MRF24F40.
THANK YOU ONCE AGAIN.
Jacob
enkavak
respond
PostPosted: Mon May 18, 2009 8:51 am     Reply with quote
Hello jjacob
Could you share your files if you had some progress on MRF24J40.
Kind regards
engin
jjacob
PostPosted: Wed May 20, 2009 2:40 pm     Reply with quote
Hello.
I haven't tried any code Sad
I only tested the hardware.
Sorry. A priority project has appeared.
As soon as I have some code, I'll post it ...
Jacob
Fram_fr
PostPosted: Thu May 28, 2009 4:46 am     Reply with quote
Hi all,
Because I will use MRF24J40 in some weeks, I start to write a driver for this chipboard, so here is a first piece of code (the low level routines which read and write to the MRF24J40 via the SPI interface) inspired by PCM programmer:
First need to define CS pin:
#define MRF24J40_CS PIN_xx
 * Function:        void SetShortRAMAddress(int8 address, int8 value)
 * PreCondition:    Communication port to the MRF24J40 initialized
 * Input:           BYTE address is the address of the short RAM address
 *                      that you want to write to.  Should use the
 *                      WRITE_ThisAddress definition in the MRF24J40
 *                      include file.
 *                  BYTE value is the value that you want to write to
 *                      that register
 * Output:          None
 * Side Effects:    The register value is changed
 * Overview:        This function writes a value to a short RAM address
spi_write(value);
 * Function:        void SetLongRAMAddress(int16 address, int8 value)
 * Input:           WORD address is the address of the LONG RAM address
 *                      that register
 * Output:          None
 * Overview:        This function writes a value to a LONG RAM address
spi_write(((address>>3)&0b01111111)|0x80);
spi_write(((address<<5)&0b11100000)|0x10);
spi_write(value);
 * Function:        void GetShortRAMAddress(int8 address)
 *                      that you want to read from.  Should use the
 *                      READ_ThisAddress definition in the MRF24J40
 *                      include file.
 * Output:          BYTE the value read from the specified short register
 * Side Effects:    None
 * Overview:        This function reads a value from a short RAM address
int8 GetShortRAMAddress(int8 address)
int8 toReturn;
spi_write(((address<<1) & 0b01111110));
return(toReturn);
 * Function:        int8 GetLongRAMAddress(int16 address)
 * Input:           WORD address is the address of the long RAM address
 * Output:          BYTE the value read from the specified Long register
 * Overview:        This function reads a value from a long RAM address
int8 toReturn;
return(toReturn);
Gus
PostPosted: Fri Sep 04, 2009 3:51 pm     Reply with quote
Hi.
I did all our friend PCM programmer said, but when I run this program in proteus,
#include <WSN.h>
#define RESET   PIN_C0
#define WAKE   PIN_C1
#define CS   PIN_C5
#define SCK   PIN_B6
void SetShortRAMAddress(int direccion, int valor)
   output_low(CS);
   spi_write(((direccion<<1) & 0b01111111) | 0x01);
   spi_write(valor);
   output_high(CS);
   int prueba = 0;
   printf("\fComenzando Programa");
   setup_adc_ports(sAN0|sAN1|VSS_VDD);
   setup_adc(ADC_OFF);
   output_high(CS);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_RDA);
   ext_int_edge( H_TO_L );
   // TODO: USER CODE!!
   SetShortRAMAddress(0x3A,0x09);
   printf("\n\r\n\rPrograma Concluido.");
   while(TRUE);
I always get this output:
http://i25.tinypic.com/16i6x3m.jpg
My PIC never sends a second complete word. It seems like something stops the SPI transmission.
Please someone can explain me why this happens???
quique
PostPosted: Mon Oct 26, 2009 11:42 am     Reply with quote
Hi:
I'm Enrique, I'm working with MRF24J40MA in my final project carrer. I'm industrial engineering and I am not capable to do...anything. I've built a little robot and i want connect with PC. In my robot I have a 18F2550 and I use MiWi because it is enough. To begin I want put in the Hyperterminal a message when a contact sensor is active but I don't know how...
Can you help me?
Thanks for advance
Best Regards
Enrique
MONZURUL
Zigbee basics
PostPosted: Fri Nov 27, 2009 7:53 pm     Reply with quote
I've just started with MRF24J40MA. Any tutorial code? Very simple with PIC32 or any other? Just to send and receive data from PC ?
Regards,
ALAM
bkamen
PostPosted: Fri Nov 27, 2009 8:28 pm     Reply with quote
You are releasing slave select before the buffer is empty.
It's common for this to happen with the hardware SPI.
Consider:
You push a byte into the TX register and then maybe(?) delay and then go release nSS.
but how does the code know when the TX buff is actually empty?
if you don't check, you don't know and end up releasing nSS early. (oops).
use a delay -- OR -- I think the empty flag for the TXbuf (I'd have to look at the datasheet again).
-Ben
rimaz_786
need ur help
PostPosted: Tue Dec 29, 2009 11:06 pm     Reply with quote
Hi Jacob and other reply friends..
I'm currently doing a project on alarm using RF security remote control system.
I have bought
MICROCHIP - MRF24J40MA-I/RM - MODULE,RF, TRANSCEIVER, 802.15.4 STD
and MICROCHIP - PIC18LF2550-I/SP - MCU, 8-BIT, 32K FLASH, SPDIP28
Please give some ideas on this project. I'm a 1st year engineering student so I don't have a very good knowledge to end up this project. I hope you will do your best for me.
Waiting for your reply.
rimaz_786@yahoo.com
rimaz
Lord_kian
PostPosted: Tue Apr 06, 2010 5:32 pm     Reply with quote
Hi people
I'm also working with this module and I need help with the miwi protocol to be used with a PIC18F452, if someone can help me to change the code to work with this pic.
Bonk
MRF24J40MA
PostPosted: Mon Apr 19, 2010 5:37 pm     Reply with quote
If you still need some help with MRF24J40MA, then please email me or visit my website. If PIC18F452 is a Microchip product, then send me a data sheet that has a description of the SPI module.
www.MRF24J40MA.com
Life is short, the things that make you curse as just a motivation to work harder!
Very Happy
temopic
PostPosted: Wed Apr 28, 2010 5:59 pm     Reply with quote
Does anyone have an example for the module?
Rocket
PostPosted: Sat May 28, 2011 3:02 am     Reply with quote
Hi.
This might be very optimistic, but is there someone who is willing to share working code with the rest of us plz.
J.I.L.
Goto page 1, 2  Next
Page 1 of 2
