		| Author | Message |
		| thomas Guest
				| Using CCS with CodeWright |
				|  Posted: Thu May 15, 2003 11:27 pm |   |
				| Hi everyone,
 I want to edit and compile PICC under CodeWright.  I tried to setup the command line but it doesn't work.  It looks like this:
 ${FTEE} "C:\Program Files\PICC\CCSC.exe" +FM E:\Project\Test\main.c
 I also want to be able to click on the error message and automatically jump to the error line.  Is it possible?
 Regards
 Thomas
 ___________________________
 Original Post ID: 144514501
		| PCM programmer
				| Re: Using CCS with CodeWright |
				|  Posted: Fri May 16, 2003 11:42 am |   |
				| :=Hi everyone, :=
 :=I want to edit and compile PICC under CodeWright.  I tried to setup the command line but it doesn't work.  It looks like this:
 :=${FTEE} "C:\Program Files\PICC\CCSC.exe" +FM E:\Project\Test\main.c
 Try this one, from the archives:
 <a href="http://www.pic-c.com/forum/general/posts/12546.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12546.html</a>
 Original Post ID: 144514511
		| thomas Guest
				|  Posted: Sat May 17, 2003 11:30 am |   |
				| Thank you for your help!  I tried this one already but it still doesn't work.
 :=:=Hi everyone,
 :=:=I want to edit and compile PICC under CodeWright.  I tried to setup the command line but it doesn't work.  It looks like this:
 :=:=${FTEE} "C:\Program Files\PICC\CCSC.exe" +FM E:\Project\Test\main.c
 :=Try this one, from the archives:
 := <a href="http://www.pic-c.com/forum/general/posts/12546.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/12546.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12546.html</a></a>
 Original Post ID: 144514524
		| davidpk Guest
				|  Posted: Sat May 17, 2003 5:43 pm |   |
				| I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line: "c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
 I used the following options:
 No command shell
 Save all files
 :=Thank you for your help!  I tried this one already but it still doesn't work.
 Original Post ID: 144514528
		| thomas Guest
				|  Posted: Sun May 18, 2003 9:01 pm |   |
				| Thank you for your help!  Using this command line, do you get it work properly?  I tried this but still, it doesn't work.  Would you please point me to a document or something about what the +DC, +LN, etc option mean? Thanks!
 Thomas
 :=I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
 :="c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
 :=I used the following options:
 :=No command shell
 :=Save all files
 :=:=Thank you for your help!  I tried this one already but it still doesn't work.
 Original Post ID: 144514535
		| davidpk Guest
				|  Posted: Wed May 21, 2003 11:14 am |   |
				| The switches you're asking about are in the Compiler Manual, page 2. What version of CodeWright are you using? I was able to do this with versions 6.5 and 7.5. Also, did you set the check boxes the same way I did?
 Oh, (just in case) you did use your source code path, not mine, right?
 :=Thank you for your help!  Using this command line, do you get it work properly?  I tried this but still, it doesn't work.  Would you please point me to a document or something about what the +DC, +LN, etc option mean?
 :=Thanks!
 :=Thomas
 :=:=I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
 :=:="c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
 :=:=I used the following options:
 :=:=No command shell
 :=:=Save all files
 :=:=:=Thank you for your help!  I tried this one already but it still doesn't work.
 Original Post ID: 144514634
		| thomas Guest
				|  Posted: Wed May 21, 2003 1:46 pm |   |
				| The code was compile OK.  My problem is when I double-click on the error message, CodeWright is unable to open the file with error and jump to the appropriate place.  I think it has to do with the way CodeWright interprets the error message. Thank you for your help!
 Regards,
 Thomas
 :=The switches you're asking about are in the Compiler Manual, page 2. What version of CodeWright are you using? I was able to do this with versions 6.5 and 7.5. Also, did you set the check boxes the same way I did?
 :=Oh, (just in case) you did use your source code path, not mine, right?
 :=:=Thank you for your help!  Using this command line, do you get it work properly?  I tried this but still, it doesn't work.  Would you please point me to a document or something about what the +DC, +LN, etc option mean?
 :=:=Thanks!
 :=:=Thomas
 :=:=:=I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
 :=:=:="c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
 :=:=:=I used the following options:
 :=:=:=No command shell
 :=:=:=Save all files
 :=:=:=:=Thank you for your help!  I tried this one already but it still doesn't work.
 Original Post ID: 144514644
 | You cannot post new topics in this forum You cannot reply to topics in this forum
