transmit MIDI message to a PC software via USB
Oscar
PostPosted: Sat Feb 23, 2013 5:51 pm     Reply with quote
I am a beginner and now doing a USB-MIDI project on 18F2550. I would like to transmit MIDI message to a PC software via USB. According to nakarman's work:
http://www.ccsinfo.com/forum/viewtopic.php?p=93141
I am able to install the driver for pic on host and the MIDI software(like MIDI-OX) can recognize the device, but no MIDI message was monitored. here is nakarman's code:
#include <18F2550.h>
//#define USB_CON_SENSE_PIN PIN_B2   //CCS 18F4550 development kit has optional connection sense pin
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN      //~~~ 20MHZ OSCILLATOR CONFIGS ~~~//
#use delay(clock=48000000/*, RESTART_WDT*/)
#DEFINE USB_HID_DEVICE     FALSE
#define USB_EP1_TX_ENABLE  USB_ENABLE_BULK  //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP2_RX_ENABLE  USB_ENABLE_BULK  //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_TX_SIZE    64  //size to allocate for the tx endpoint 1 buffer
#define USB_EP2_RX_SIZE    64   //size to allocate for the rx endpoint 1 buffer
#include <pic18_usb.h>
#include <descriptors.h>   //USB Configuration and Device descriptors for this UBS device
#include <usb.c>           //handles usb setup tokens and get descriptor reports
int8 rxdata[8];
void main(void) {
   //int1 run=0;
   //int16 ms_counter;
   unsigned char buf[4];
   printf("\r\n\nCCS USB Bulk Example\r\nPCH: v");
   printf(__PCH__);
   usb_init_cs();
   printf("\r\n\n");
   while (TRUE) {
      usb_task();
      if(usb_enumerated()) {
         //if (run)
         //   usb_scope_task();
         if (usb_kbhit(2)) {
            usb_get_packet(1,rxdata,8);
            //printf("\r\n--> Received 2 bytes: Thresh=%U Delay=%U",threshold,sample_rate);
         //HERE i differently try to send midi data to pc
         //buf[0] = (3 << 4) | 0x09;
         buf[1] = 0x93;
         buf[2] = 12;
         buf[3] = 64;
         usb_put_packet(1, buf, 4, USB_DTS_TOGGLE);
         delay_ms(250);
         buf[0] = (4 << 4) | 0x09;
         delay_ms(250);
         usb_puts(1, 0x3BB01919, 4, 250);
         delay_ms(250);
         //falsh led
         output_bit(PIN_B7,1);
       delay_ms(200);
       output_bit(PIN_B7,0);
anyone can help?
