Internal Error - Contact CCS Hidden forward reference 315 f
nurquhar
PostPosted: Tue Feb 19, 2013 11:11 am     Reply with quote
I am getting this error for PCH 4.133. The inclusion of "usb_cdc.h" seems to be the cause in this simple two file project. Sad
The usb_cdc.h is there because I want to use the usb in my application. I have cut it all down to this to demonstrate the problem.
i.e. I can compile it if I remove the second source file (readbat.c) and the reference to test(), or if I comment out the usb_cdc.h include.
Any ideas why it happens. Question I guess I will have to go back to using "one" source file as per v3. Rolling Eyes
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH "bug.c" +EXPORT +DF +LN +T +A +M +Z +Y=9 +EA
>>> Warning 203 "C:\Program Files\PICCv4\drivers\pic18_usb.c" Line 609(1,1): Condition always TRUE
N:\Projects\RonHaselden\Eyes\PIC\demo1\bug.o ===>  0 Errors,  1 Warnings.
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH "readbat.c" +EXPORT +DF +LN +T +A +M +Z +Y=9 +EA
N:\Projects\RonHaselden\Eyes\PIC\demo1\readbat.o ===>  0 Errors,  0 Warnings.
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH LINK="demo1.hex=bug.o,readbat.o" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 44 "demo1.c" Line 1(0,1): Internal Error - Contact CCS  Hidden forward reference 315 from 249
      1 Errors,  0 Warnings.
Build Failed.
Skipping link step.  Not all sources built successfully.
BUILD FAILED: Tue Feb 19 16:57:58 2013
Bug.c
#include <18F27J53.h>
#use delay(clock=48M)
#include <readbat.h>
#include <usb_cdc.h>
   test();
readbat.h
#ifndef __READBAT_H__
#define __READBAT_H__
void test() ;
//void ReadBGRef() ;
//int ReadBatSense() ;
// __READBAT_H__
#endif
readbat.c
void test()
   int a, b ;
   a = 1 ;
   b = a ;
PostPosted: Tue Feb 19, 2013 1:58 pm     Reply with quote
You are trying to use functions across modules, but have not exported the functions or imported the functions.
Read the linker section of the manual, and look at the examples.
nurquhar
PostPosted: Wed Feb 20, 2013 3:59 am     Reply with quote
Ok I have looked at MCU.zip example and there is still something I am not understanding. Confused
I followed the instructions in "Using Multiple Compilation Units Guide.pdf" and built the project setup in MPLAB as per the step by step instructions. I ran build all and succesfully got it compile :
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FM "report.c" +EXPORT +DF +LN +T +A +M -Z +Y=9 +EA
C:\Temp\PIC\mcu\Example Files\report.o ===>  0 Errors,  0 Warnings.
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FM "filter.c" +EXPORT +DF +LN +T +A +M -Z +Y=9 +EA
C:\Temp\PIC\mcu\Example Files\filter.o ===>  0 Errors,  0 Warnings.
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FM "main.c" +EXPORT +DF +LN +T +A +M -Z +Y=9 +EA
C:\Temp\PIC\mcu\Example Files\main.o ===>  0 Errors,  0 Warnings.
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FM LINK="MCU.hex=report.o,filter.o,main.o" +DF +LN +T +A +M -Z +Y=9 +EA
      Memory usage:   ROM=14%      RAM=10% - 16%
Build Successful.
Loaded C:\Temp\PIC\mcu\Example Files\MCU.cof.
BUILD SUCCEEDED: Wed Feb 20 09:08:22 2013
So I now try to use "usb_cdc.h" in the main.c. To do this I make the following changes :
1. Change "configure" to use device "PIC18F27J52"
2. Add "#include <usb_cdc.h> " to main.c
3. Comment out "#include <16F877A.h>" and add #include <18F27J53.h> to project.h
4. Comment out #fuses in project.h
main.c :
#include "project.h"
#include "report.h"
#include "filter.h"
#include <stdlib.h>
#include <input.c>
extern long report_line_number;
void main(void) {
project.h
//#include <16F877A.h>
//#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20mhz)
#use rs232(BAUD=9600, UART1, STREAM=PC)
enum errors { err_range, err_too_far, err_too_many };
OUTPUT
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH "report.c" +EXPORT +DF +LN +T +A +M -Z +Y=9 +EA
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH "filter.c" +EXPORT +DF +LN +T +A +M -Z +Y=9 +EA
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH "main.c" +EXPORT +DF +LN +T +A +M -Z +Y=9 +EA
C:\Temp\PIC\mcu\Example Files\main.o ===>  0 Errors,  1 Warnings.
Build Successful.
Executing: "C:\Program Files\PICCv4\Ccsc.exe" +FH LINK="MCU.hex=report.o,filter.o,main.o" +DF +LN +T +A +M -Z +Y=9 +EA
*** Error 44 "MCU.c" Line 1(0,1): Internal Error - Contact CCS  Hidden forward reference 620 from 554
Build Failed.
BUILD FAILED: Wed Feb 20 09:19:22 2013
Still the same compiler error Exclamation
I also tried the command line "buildall.bat" method after changing +FM to +FH so it uses PCH. Still get the "ERROR". Exclamation
buildall.bat
C:\Temp\PIC\mcu\Example Files>cbuildall.bat
C:\Temp\PIC\mcu\Example Files>"C:\Program Files\PICCv4\CCSC.exe" +FH +EXPORT rep
ort.c
C:\Temp\PIC\mcu\Example Files>"C:\Program Files\PICCv4\CCSC.exe" +FH +EXPORT fil
ter.c
C:\Temp\PIC\mcu\Example Files>"C:\Program Files\PICCv4\CCSC.exe" +FH +EXPORT mai
n.c
C:\Temp\PIC\mcu\Example Files>"C:\Program Files\PICCv4\CCSC.exe" +FH LINK="proje
ct.hex=report.o,filter.o,main.o"
C:\Temp\PIC\mcu\Example Files>type *.err
filter.err
No Errors
Build Successful.
main.err
No Errors
Build Successful.
project.err
Error[44]   project.c 1 : Internal Error - Contact CCS  Hidden forward reference
 620 from 554
Build Failed.
report.err
No Errors
Build Successful.
nurquhar
PostPosted: Wed Feb 20, 2013 4:12 am     Reply with quote
Build Successful.
Build Successful.
Build Successful.
Build Successful.
main.c :
#include "report.h"
#include "filter.h"
#include <stdlib.h>
#include <input.c>
void main(void) {
project.h
OUTPUT
Clean: Done.
Build Successful.
Build Successful.
Build Successful.
Build Failed.
buildall.bat
ort.c
ter.c
n.c
filter.err
No Errors
Build Successful.
main.err
No Errors
Build Successful.
project.err
 620 from 554
Build Failed.
report.err
No Errors
Build Successful.
PostPosted: Wed Feb 20, 2013 10:16 am     Reply with quote
I've just done the same. Took the MCU example, modified it for your chip (you need fuses....). Added usb_cdc.h, and calls to usb_init, usb_task, and usb putc.
Compiled it with 4.118, 4.137, and 4.140, and all happily compiled it. Tried both with the batch files, and from the IDE. I'd suspect part of your install is corrupt. Haven't got 4.134, maybe there was a problem with that release.
nurquhar
PostPosted: Wed Feb 20, 2013 11:06 am     Reply with quote
Well it must be some snafu with 4.133 rather than something I didn't know about multi unit compiling.
I install 4.129, buildall.bat works correctly :
C:\Temp\PIC\mcu\Example Files>"C:\Program Files\PICCv4\CCSC.exe" +V
ort.c
C:\Temp\PIC\mcu\Example Files>"C:\Program Files\PICCv4\CCSC.exe" +FH +EXPORT filter.c
n.c
filter.err
No Errors
Build Successful.
main.err
No Errors
Build Successful.
project.err
No Errors
Build Successful.
report.err
No Errors
Build Successful.
CCS PCH C Compiler, Version 4.129, 61227               20-Feb-13 16:48
               Filename: C:\Temp\PIC\mcu\Example Files\project.lst
               ROM used: 6328 bytes (5%)
                         Largest free fragment is 65528
               RAM used: 454 (12%) at main() level
                         498 (13%) worst case
               Stack:    12 worst case (3 in main + 9 for interrupts)
Re-installing 4.133 :
ort.c
ter.c
n.c
filter.err
No Errors
Build Successful.
main.err
No Errors
Build Successful.
project.err
 620 from 554
Build Failed.
report.err
No Errors
Build Successful.
