hemnath
blinking LED using timer1? |
Posted: Sun Feb 03, 2013 6:49 am |
I want to blink 2 led's with different timings. Using internal Oscillator 4Mhz
LED1 ON 2sec and OFF 5 sec
LED2 ON 3sec and OFF 6sec
I have written the code. But the timings is not perfect.
Using timer1, i set up an interrupt to occur for every 1 ms to go into the interrupt routine.
unsigned int16 LED1_ON=0, LED1_OFF=0, LED2_ON=0, LED2_OFF=0;
int1 LED1_ON_flag = 0, LED1_OFF_flag = 0, LED2_ON_flag = 0, LED2_OFF_flag = 0;
// In timer1 routine, incrementing these variables,
LED1_ON++;
LED1_OFF++;
LED2_ON++;
LED2_OFF++;
if(LED1_ON == 2000) // if equals 2 secs
LED1_ON = 0;
LED1_ON_flag = 1;
if(LED1_OFF == 5000) // if equals 5 secs
LED1_OFF = 0;
LED1_OFF_flag = 1;
if(LED2_ON == 3000) // if equals 3 secs
LED2_ON = 0;
LED2_ON_flag = 1;
if(LED2_OFF == 6000) / if equals 6 secs
LED2_OFF = 0;
LED2_OFF_flag = 1;
// in the main program
output_low(LED1);
output_low(LED2);
if(LED1_ON_flag == 1)
LED1_ON_flag = 0;
//LED1_ON = 0;
output_high(LED1);
if (LED1_OFF_flag == 1)
LED1_OfF_flag = 0;
//LED1_ON = 0;
output_low(LED1);
if(LED2_ON_flag == 1)
LED2_ON_flag = 0;
//LED2_ON = 0;
output_high(LED2);
if(LED2_OFF_flag == 1)
LED2_OFF_flag = 0;
//LED2_OFF = 0;
output_low(LED2);
I simulated in proteus, but the LED blinks for different timings. Wat could be the problem? please help |
Mike Walne
Posted: Sun Feb 03, 2013 9:23 am |
Forget Proteus, search this forum to find out what others think.
If you must simulate use MPLAB.
Is your code complete and compilable?
Show us PIC, compiler version etc as advised in forum guidelines.
Tell us what your real hardware is doing.
Mike |
Humberto
Posted: Sun Feb 03, 2013 9:47 am |
Looking at your code I guess that you should learn 'C' codding. We can help you, but you must have the minimum skills to do the
"Blinking LED test" for yourself.
To achieve you need: a basic knowledge of C language structure, how to define a function prepositions and call a functions,
know the C programm layout, etc.
Basic knowledge of the MCU hardware in your project (you do not mention ) and the minimum skills to handle the electronic
hardware involved.
I strongly suggest to read some book regarding "C + PIC MCU for Beginners":
http://www.ccsinfo.com/content.php?page=books
Read and study the CCS examples codes that is included with your CCS Compiler in the Examples Folder.
Take a trip for this site:
http://www.ccsinfo.com/faq.php
Last suggestion: DO NOT mention the word 'Proteus' in this forum (unless you are talking of Greek Mythology).
Read this and you will understand what I mean:
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
Regards
Humberto
Posted: Sun Feb 03, 2013 11:57 am |
Also, programs to do exactly this, have been posted here inside the last month. Use search.
