cbarberis
Joined: 01 Oct 2003 Posts: 172 Location: Punta Gorda, Florida USA
HELP with dsPIC running on I2C Slave mode |
Posted: Sat Feb 16, 2013 6:31 pm |
Hopefully, some smart person will see whatever stupid thing I am doing wrong. I am trying to send some data via I2C from one PIC to another. In this case just for testing, I'm using a PIC184520 as the master, all the master does is just send two bytes, the first one with the address of the slave (dsPIC33JF12GP201) and the W/R on the LSB and the next following byte contains 8 bits of data. This is part of a high voltage controller design, where the dsPIC does the high voltage control via the I2C bus.
I have done this many times in the past with PIC18 series of devices with great success, but for some reason it does not want to work with the dsPIC device. I am using PCD V4.140 which is the latest compiler version. Basically, what is happening (or not happening) is that the master device sends the two bytes via I2C to the dsPIC and the dsPIC (slave) then gathers this information and performs a PID control loop on a HV supply. Simply put, what is not happening here is that the I2C interrupt on the slave device never takes place, I have tried everything possible to no avail. It may be me or it may be CCS but in either case it does not work and I just don't want to re-write the whole thing on MPLAB C30.
This is the code for the MASTER:
#include <main.h>
#define SLAVEADDRESSW 0x0C // slave address when writing
#define SLAVEADDRESSR 13 // slave address when reading
unsigned int commandvalue =25;
void Init()
setup_adc_ports(NO_ANALOGS);
//setup_oscillator(OSC_8MHZ|OSC_TIMER1|OSC_31250|OSC_PLL_OFF);
setup_wdt(WDT_OFF);
Init();
delay_ms(1000);///wait a sec so slave can be set up
while(1){
if(!input(PIN_D0)) /// we press a switch here and just send some data to the slave
{ commandvalue += 5;
i2c_start();
i2c_write(SLAVEADDRESSW);
i2c_write(commandvalue);
i2c_stop(); }
output_high(PIN_D3); ///this is just to make sure this puppy is running
output_low(PIN_D3);
restart_wdt();
The code below is for the SLAVE:
#include <33FJ12GP201.h>
#device *=16
#device ICD = 1
#FUSES FRC,NOWDT,CKSFSM,NOJTAG,DEBUG
#use delay(clock=7.37MHz,RESTART_WDT)
#pin_select OC1 = PIN_B4
#use i2c(i2c1,Slave,slow,force_hw,address=0x0C)
#define HVCONTROL PIN_B7
#define HVON output_low(PIN_B15)
#define HVOFF output_high(PIN_B15)
#define SLAVEADDRESSW 0xC // slave address when writing
#define SLAVEADDRESSR 0xD // slave address when reading
#define COMMANDBYTE 0x80
#define I2CBUFFER_SIZE 3
unsigned int8 Rxbuffer[I2CBUFFER_SIZE];
unsigned int8 Txbuffer[I2CBUFFER_SIZE];
unsigned int8 state,incoming,address;
int1 I2CReceiveFlag = 0;
int1 ActiveFlag = 0;
unsigned int8 CommandValue;
unsigned int8 SetPointValue = 0;
///#include "C:\PICOMP\FILES\Sage\NewPippinsPulsePSC\PID.C" //
#int_EXT0
void EXT0_isr(void)
#INT_SI2C
void i2c_isr(void)
state = i2c_isr_state();
if(state < COMMANDBYTE) //Master is sending data to us
{ incoming = i2c_read(); // Get I2C data byte
switch (state) { // Filter out individual bytes
case 0: // if state is zero then we have the first byte = Address Byte and R/W bit direction
address = incoming;
case 1: // if state is one then we have the second byte or first data byte
Rxbuffer[0] = incoming;
case 2: // if state is two then we have the third byte or second data byte NOT USED at the moment
Rxbuffer[1] = incoming;
break; }
if(state == 1) // if we got all data bytes that we need
I2CReceiveFlag = 1; // Set the flag so we can process the entire data transfer
void Init(){
//RB8_TRIS =1;
//RB9_TRIS =1;
setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1,1024 );
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_4);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
HVOFF;
set_pwm_duty(1,0);
set_adc_channel(0);
//A10M = 0;
//enable_interrupts(INT_EXT0);
enable_interrupts(INT_SI2C);
{ unsigned int Reading;
Init();
while(1){
if(I2CReceiveFlag) // Process incoming I2C commands
{ SetPointValue = Rxbuffer[0];
output_low(PIN_B14);
I2CReceiveFlag = 0; }
if(!input(HVCONTROL))
{ HVON;
ActiveFlag = 1;}
{ HVOFF;
ActiveFlag = 0;}
ControlSetpoint = (float)SetPointValue;
pid();
//Reading = read_adc();
delay_ms(SAMPLETIME);
restart_wdt();
cbarberis
Posted: Sun Feb 17, 2013 9:39 pm |
Amazingly enough after many hours of playing with this I have got it to work but there is something that I truly don't seem to understand. It appears that changing the slave address on both the master and slave to an address of 0x10 works ok, however addresses like 0x08 or 0x0C do not work!..Now I know these are valid addresses for 7 bit slave command bytes, so I don't really understand what is really happening, at least not with clarity. In the previous code I posted I show the parameter "slow" on the #use i2c() statement, this should not be there and had nothing to do with the original problem. Another thing to be said about debugging this; originally I tried using Proteus ISIS to do the simulation and debugging, unfortunately the results I got sent me in the wrong direction as I waisted many precious hours trying to debug this. I finally built a breadboard with the actual parts and finally got it to work (Proteus still tells me it does not work)
Perhaps someone can shed some light on such subject ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
Posted: Sun Feb 17, 2013 10:02 pm |
They are not valid. They are reserved. Look in the table in the upper
left corner on page 16 of the i2c Spec:
www.nxp.com/documents/other/39340011.pdf
It shows that addresses 0x08 and 0x0C are reserved for "Hs-mode master code".
Note: The table shows 7-bit slave addresses, so just add a zero onto
the right side to convert it to CCS 8-bit format. An "X" means "don't
care" which means that bit can be 0 or 1. |
cbarberis
Posted: Mon Feb 18, 2013 7:58 am |
Thank you PCM programmer! But I am still somewhat confused about these addressing limitations. According to a very good piece of info I found here a while back, see:
http://www.totalphase.com/support/kb/10039/#8bit
The address I was using should be OK, well, I should re-state not "should" but it is. I have been using address 0x08 for a slave device that has been in production for more than two years and it works just fine. According to the above literature valid addresses for slaves using 7bit are from 0x08 to 0x77. Perhaps I am still misinterpreting the rules, I guess my question now is, are the so called "reserved addresses" addresses that you are not supposed to use, but however if you use them the hardware will work anyway or are these addresses which the hardware will determine not to be utilized and will not work? |
Posted: Mon Feb 18, 2013 1:45 pm |
It doesn't matter what some 3rd party website says. What matters is:
1. The Philips i2c spec.
2. The Microchip documentation.
Download the i2c part of the Microchip Reference manual:
Section 19. Inter-Integrated Circuitâ„¢
ww1.microchip.com/downloads/en/DeviceDoc/70195E.pdf
Look on page 37 and you'll find a table of Reserved Addresses.
It's the same table as in the Philips i2c spec. The paragraph
above the table says bluntly that these addresses will be ignored
and the PIC will not issue an Ack.
Now it may be that in some other PIC you got away with it. Perhaps
those addresses weren't properly locked out by silicon design of the
MSSP module. But a very important rule in electronics is "don't violate
a spec". |
cbarberis
Posted: Mon Feb 18, 2013 2:45 pm |
OK, I have read the Microchip document you referred to and it appears to be "the law" if it is masked in silicon thou shall not violate it!
Based on the table of addresses I saw one comes to the conclusion you can only use slave addresses from 0x10 - 0xE0 (using seven bit addressing) is that correct? |
Posted: Mon Feb 18, 2013 3:21 pm |
The allowable i2c slave base address range is 0x10 through 0xEE.
Those are 8-bit addresses. |
