rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
| error: Function used but not defined ??? |
Posted: Wed Jan 16, 2013 1:15 pm |
Why I get an error by compiling this program? What does this error mean?
Here is the code:
#include <18F4550.h>
#fuses NOWDT,NOMCLR,HS,USBDIV,PLL4,VREGEN,CPUDIV1
#use delay(clock=16M)
#include <usb_cdc.h>
#INCLUDE <stdlib.h>
int i;
char str[];
usb_cdc_init();
usb_init_cs();
usb_init();
while (true)
usb_task();
if(usb_cdc_kbhit())
i=get_int_usb(); //I have error on this line
usb_cdc_putc(i);
The error is:
Function used but not defined .... get_int_usb() SCR=9201
What is wrong with my code? _________________ A person who never made a mistake never tried anything new. |
Posted: Wed Jan 16, 2013 1:39 pm |
You need to load stdlib.h
The getint function uses atoi, which is not present, till stdlib is loaded.
rikotech8
Posted: Wed Jan 16, 2013 2:22 pm |
Thanks for answer, but I'm not sure what I need to do by loading stdlib.h?
And how exactly to load stdlib, I have included the file already. What means to load stdlib.h/
Thanks again! _________________ A person who never made a mistake never tried anything new. |
Posted: Wed Jan 16, 2013 2:33 pm |
It needs to be _in front_ of the usb file.
rikotech8
Posted: Thu Jan 17, 2013 1:03 pm |
Thanks to both of you! My problem has been solved. _________________ A person who never made a mistake never tried anything new. |
