Pic18F25K22 int osc 64 MHz
horizontechno
PostPosted: Sat Dec 29, 2012 9:48 pm     Reply with quote
Hi
I need to get same starting header with fuse and setup oscillator to get
PIC18F25K22 running at 64 MHz with internal oscillator ?
I have try this at 16 MHz but nothing on pin a0 ?
Alain
#include <18f25k22.h>
#FUSES INTRC_IO
#FUSES NOPROTECT
#FUSES NOEBTRB
#FUSES NOEBTR
#FUSES NOWRTC
SC
#FUSES NODEBUG
#device icd=true
#use delay(clock=16Mhz)
void Main(void){
setup_oscillator(OSC_16MHZ);
test:
delay_ms(1);
output_high(pin_a0);
delay_ms(1);
output_low(pin_a0);
Mike Walne
PostPosted: Sun Dec 30, 2012 3:02 am     Reply with quote
As it stands pin_a0 only goes high for 1ms. You could easily miss it
delay_ms(1);
delay_ms(1);
output_low(pin_a0);
Try this instead
while (1)
     output_low(pin_a0);
Connect an LED (with current limit resistor) to pin_a0, you'll see LED flash at 1Hz (IF everything is working correctly).
Mike
horizontechno
PostPosted: Sun Dec 30, 2012 8:24 pm     Reply with quote
Thank you !!
Basic mistake ...
Alain
