matheuslps
| Simple PWM with ECCP in D7 PIN |
Posted: Sat Dec 29, 2012 9:38 am |
Hi guys, I am tring to learn how to use the ECCP module with the PIC 18F45K20.
I was able to configure it to show me a singnal on the CCP1 (P1A) with the code:
| Code: | #include <18F45K20.h>
#FUSES XT //Crystal osc <= 4mhz
#FUSES PUT //Power Up Timer
#use delay (clock=4000000)
void main ()
setup_timer_2(T2_DIV_BY_16,207,1);
setup_ccp1(CCP_PWM_HALF_BRIDGE|CCP_PWM_H_H);
set_pwm1_duty(416L); //Should be 50% duty cycle
while (true);
I need this signal on pin D7 (P1D). Is it possible to run the signal only on that pin?
Version: 4.114 and 4.057
thanks |
Posted: Sat Dec 29, 2012 12:20 pm |
You don't want half bridge mode.
Just start with the single PWM mode (CCP_PWM).
This then defaults to P1A.
You then have to change the pulse steering register to direct this output to P1D (CCP_PULSE_STEERING_D).
So:
void main ()
setup_ccp1(CCP_PWM|CCP_PULSE_STEERING_D);
//on some compiler versions you may need to set TRIS here
output_drive(PIN_D7);
while (true);
Should work with 4.114 (would _not_ trust 4.057 - this was before V4 started to really work).
matheuslps
Posted: Sat Dec 29, 2012 5:10 pm |
| Thanks man, working like a charm! |
