YeyoPIC
Modbus address selected with dip switches |
Posted: Thu Dec 13, 2012 4:48 am |
Hi all, this is my first post here and I want to know how can I make preprocessors directives after of dip switches read.
For example, I am using modbus.c library for some test and I want to read a dip switch connected to portb to assign the modbus address and baudrate. I will take ex_modbus_slave.c, something like this...
#define MODBUS_BUFFER_SIZE 32
#define MODBUS_ADDRESS 1 //here I want to asign the dip switch value
#define MODBUS_SERIAL_BAUD //and here too
If I do this could change the address without rewrite the Pic with each address.
How I can do that?
Thanks in advance. |
asmallri
Re: Modbus address selected with dip switches |
Posted: Thu Dec 13, 2012 6:03 am |
YeyoPIC wrote: | Hi all, this is my first post here and I want to know how can I make preprocessors directives after of dip switches read.
How I can do that?
If you think a bit more about what you are asking you would realise it is a silly question.
You are asking how a compile time directive can be changed based on the reading of a DIP switch setting at run time. Unless you have implemented in your code, some form of communication system for passing data through worm holes traversing parallel universes, it is not possible.
Instead should be asking yourself, how can I populate a variable at run time from the setting of DIP switches than can then be used to configure the modbus address. _________________ Regards, Andrew
YeyoPIC
Posted: Thu Dec 13, 2012 6:23 am |
Sorry, I'm wrong.
My question is exactly that "how can I populate a variable at run time from the setting of DIP switches than can then be used to configure the modbus address."
Do you know how I can do that?.
Joined: 01 Jul 2010 Posts: 9164 Location: Greensville,Ontario
Posted: Thu Dec 13, 2012 6:50 am |
comment..
a quick look in the 'examples' folder that CCS supplies shows several programs that do what you want.
One, I think named ' patg.c' should have the code snippet you need.
If it's not that program, check some of the others....or read the FAQ section of the onscreen Help files(press F11 when project is open).
All you're doing is reading an I/O port or part of one, then writing the data into a variable(RAM).
Obviously it's up to you as to which I/O port, pins,data manipulation,etc. as it is your program not mine.
hth
jay |
Posted: Thu Dec 13, 2012 1:49 pm |
Quote: | how can I populate a variable at run time from the setting of DIP switches
Connect the 8-position DIP switch to an i/o port on the PIC.
Each individual DIP switch circuit should look like this:
+5v
> 4.7K
< ___ Switch
To | _|_|_
PIC -----------------o o------
pin |
--- GND
You can use a larger resistor value. Instead of an external pull-up
resistor, you can enable the built-in pullup resistors on PortB (if the DIP
switch is connected to PortB).
Assuming you're using PortB with the internal pull-ups, the following
code will read the dip switches when the PIC first starts running:
int8 dipsw_value;
port_b_pullups(0xFF);
delay_ms(1);
dipsw_value = input_b(); // Read dip switches
// Do something here.
