stoyanoff
problem in compiling ex_fat.c |
Posted: Wed Dec 05, 2012 5:40 am |
Hi, everyone! I tried to compile ex_fat.c, but the complier returned an error:
"C:\Program Files (x86)\PICC\drivers\fat.c" Line 1867(37,41): Printf format type is invalid ::
It points to this row:
sprintf(cur_fnum, "%u", fnum);
I`m using mplab v8.88, ccs v4.134.
Can you tell me where is the problem??? |
Posted: Wed Dec 05, 2012 6:02 am |
Somebody forgot to type an L at CCS.....
Line needs to be:
sprintf(cur_fnum, "%lu", fnum);
The version with later compilers is OK.
stoyanoff
Posted: Wed Dec 05, 2012 6:13 am |
Thanks!
I want to ask one more thing. In ex_fat there is a row:
#device PASS_STRINGS = IN_RAM
How can I remove this row?? I tried without it but I had an error:
*** Error 90 "ex_fat.c" Line 156(28,29): Attempt to create a pointer to a constant
and it points to if(fatopen(fileName, "a", &stream) != GOODEC)
Best regards! |
Posted: Wed Dec 05, 2012 8:36 am |
Read the manual, or search here. This has been explained so many times it is obscene.....
It is one way of allowing constant strings to have pointers allocated to them. "a" is a constant string.
