PIC24HJ256GP610 SPI DOESN'T WORK FOR 4.134 *** Locked - Dup
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
ck
PostPosted: Fri Nov 30, 2012 7:50 am     Reply with quote
Locked.
Reason: Duplicate topic. No new thread on same SPI topic !
Add new code to your PIC24 SPI thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=49508
- Forum Moderator
I try this code with 2 different compile version. For 4.134 no data came out from SPI-D0. With 4.104 data come out. Any suggestion?
#include <24HJ256GP610.h>
#DEVICE ADC=12
#fuses NOWDT   //No Watch Dog Timer
#fuses NOWRTB   //Boot block not write protected
#fuses NOBSS   //No boot segment
#fuses NOPROTECT  //Code Protected form reads
#fuses NOWRT   //Program memory not write protected
#fuses PR_PLL   //Primary Oscillator with PLL
#fuses NOCKSFSM   //Clock Switching disabled
#fuses NOOSCIO   //OSC2 is clock output
#fuses HS      //Primary oscillator HS
#fuses WINDIS   //WD in non-windows mode
#fuses WPRES128
#fuses WPOSTS16
#fuses PUT128   //No Power on Reset Timer value
#fuses IESO   //Internal external switch Over mode disabked //NOIESO
#fuses NORSS   //No secure segment RAM
#fuses NOSSS   //No secure segment
#fuses NOWRTSS   //Secure segment not write protected
#fuses NORBS   //No Boot Ram defined
#fuses NODEBUG   //No debug mode
#fuses NOJTAG   //JTAG DISABLED
//reset
#word RCON   = 0x0740
//PLL
#word CLKDIV = 0x0744
#word PLLFBD = 0x0746
void main(){
        RCON=0b0000000001000000;
   CLKDIV=0;
   PLLFBD=0x1E;
   //watch dog OFF
   setup_wdt(WDT_OFF);
   #use fast_io(F)
   set_tris_f(0b0000000010110001);
   output_f(0);
   //SPI 1
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4);
              spi_write(0b010101010);
Why in case of 4.104 i see a square wave in SPI-1-DO and with 4.134 nothing?
Thanks in advantage
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
