MDIO CL22 master using bit-banging SPI
PICoHolic
PostPosted: Wed Jul 25, 2018 7:09 am     Reply with quote
mdio.h
#ifndef _MDIO_H_
#define _MDIO_H
//IO def:
#define   MDC_PIN      PIN_C0
#define MDIO_PIN   PIN_C1
#define DriveMDC()   output_drive(MDC_PIN)
#define   SetMDC()   output_high(MDC_PIN)
#define   ClearMDC()   output_low(MDC_PIN)
#define   DriveMDIO()   output_drive(MDIO_PIN)
#define   SetMDIO()   output_high(MDIO_PIN)
#define   ClearMDIO()   output_low(MDIO_PIN)
#define   FloatMDIO()   output_float(MDIO_PIN)
#define   GetMDIO()   input(MDIO_PIN)
//MDIO over SPI
#define BITRATE  500000
#use SPI(master, baud=BITRATE, bits=32, DI=MDIO_PIN, DO=MDIO_PIN, CLK=MDC_PIN, mode=0, stream=MDIO_SPI32, force_sw)
#use SPI(master, baud=BITRATE, bits=16, DI=MDIO_PIN, DO=MDIO_PIN, CLK=MDC_PIN, mode=2, stream=MDIO_SPI16, force_sw)
#use SPI(master, baud=BITRATE, bits=14, DI=MDIO_PIN, DO=MDIO_PIN, CLK=MDC_PIN, mode=0, stream=MDIO_SPI14, force_sw)
#use SPI(master, baud=BITRATE, bits=1, DI=MDIO_PIN, DO=MDIO_PIN, CLK=MDC_PIN, mode=2, stream=MDIO_SPI1, force_sw)
//Prototypes:
void MDIO_init(void);
void MDIO_write_22(unsigned int8 PHYAddress, unsigned int8 RegAddress, unsigned int16 Data);
int1 MDIO_read_22(unsigned int8 PHYAddress, unsigned int8 RegAddress, unsigned int16 *Data);
#endif
mdio.c
#include "mdio.h"
 * @author m_richa (03/09/18)
   FloatMDIO();
   ClearMDC();
   DriveMDC();
 * @param PHYAddress
 * @param RegAddress
 * @param Data
   unsigned int32 Preamble = 0xFFFFFFFF;
   unsigned int32 RawOut =     ((unsigned int32)01 << 30) | \
                       ((unsigned int32)01 << 28) | \
                       ((unsigned int32)PHYAddress << 23) | \
                       ((unsigned int32)RegAddress << 18) | \
                       ((unsigned int32)02 << 16) | \
                       (unsigned int32)Data;
   SetMDIO();
   DriveMDIO();
   //Preamble:
   spi_xfer(MDIO_SPI32, Preamble);
   //Raw data:
   spi_xfer(MDIO_SPI32, RawOut);
   //Release data:
   FloatMDIO();
 * @param PHYAddress
 * @param RegAddress
 * @param Data
 * @return int1
   unsigned int16 RawOut =     ((unsigned int16)01 << 12) | \
                       ((unsigned int16)02 << 10) | \
                       ((unsigned int16)PHYAddress << 5) | \
                       (unsigned int16)RegAddress;
   unsigned int8 TA=0;
   SetMDIO();
   DriveMDIO();
   //Preamble:
   //Raw data:
   spi_xfer(MDIO_SPI14, RawOut);
   //Release data and set clock
   FloatMDIO();
   SetMDC();
   TA = spi_xfer(MDIO_SPI1,0);
   *Data = spi_xfer(MDIO_SPI16,0);
   //Clear clock:
   ClearMDC();
   return (!bit_test(TA, 0));   //return TA state
MDIO Background:
https://www.totalphase.com/support/articles/200349206-MDIO-Background
