MPLAB X(Debug Mode): Access violation in mod PCH.dll
eacc3525
PostPosted: Wed Nov 21, 2012 11:11 am     Reply with quote
First time using MPLAB X. Tried to build PIC18F6627 program in debug mode but build failed with the error below:
CLEAN SUCCESSFUL (total time: 62ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Users/ecastro/MPLABXProjects/OpticsXTest.X'
make  -f nbproject/Makefile-default.mk dist/default/debug/OpticsXTest.X.debug.cof
make[2]: Entering directory `C:/Users/ecastro/MPLABXProjects/OpticsXTest.X'
gnumkdir -p build/default/debug/_ext/1472
gnumkdir -p dist/default/debug
"C:\PROGRA~2\PICC\CCSCON.exe"  out="dist/default/debug"  ../OpticsPdLed.c +FH +DF  #__DEBUG=1 +ICD +Y=9 +EA I+="C:\Program Files (x86)\PICC\Devices" I+="C:\Program Files (x86)\PICC\Drivers" +DF +LN +T +A +M +J +EA +Z -P #__18F6627=TRUE
C:\Users\ecastro\MPLABXProjects\pd-led.h:44:7:  Info#300  More info:   ** Access violation at address 02C65C5C in module 'PCH.dll'. Read of address 534F4E24
C:\Users\ecastro\MPLABXProjects\pd-led.h:44:7:  Error#44  Internal Error - Contact CCS
      1 Errors,  0 Warnings.
Build Failed.
mv: cannot stat `dist/default/debug/OpticsPdLed.cof': No such file or directory
make[2]: Leaving directory `C:/Users/ecastro/MPLABXProjects/OpticsXTest.X'
make[2]: *** [build/default/debug/_ext/1472/OpticsPdLed.o] Error 1
make[1]: *** [.build-conf] Error 2
make[1]: Leaving directory `C:/Users/ecastro/MPLABXProjects/OpticsXTest.X'
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 765ms)
The MPLAB X build for same PIC18F6627 using production mode finished sucesfully. Build output below:
CLEAN SUCCESSFUL (total time: 124ms)
make  -f nbproject/Makefile-default.mk dist/default/production/OpticsXTest.X.production.hex
gnumkdir -p build/default/production/_ext/1472
gnumkdir -p dist/default/production
"C:\PROGRA~2\PICC\CCSCON.exe"  out="dist/default/production"  ../OpticsPdLed.c +FH +DF +Y=9 +EA I+="C:\Program Files (x86)\PICC\Devices" I+="C:\Program Files (x86)\PICC\Drivers" +DF +LN +T +A +M +J +EA +Z -P #__18F6627=TRUE
      Memory usage:   ROM=15%      RAM=8% - 9%
      0 Errors,  0 Warnings.
Build Successful.
BUILD SUCCESSFUL (total time: 1s)
Loading code from C:/Users/ecastro/MPLABXProjects/OpticsXTest.X/dist/default/production/OpticsXTest.X.production.hex...
Loading symbols from C:/Users/ecastro/MPLABXProjects/OpticsXTest.X/dist/default/production/OpticsXTest.X.production.cof...
Loading completed
Any ideas?
PostPosted: Wed Nov 21, 2012 1:58 pm     Reply with quote
It doesn't like what it sees on that line in pd-led.h.
Post that line. Or post that line, and several lines before and after it.
eacc3525
PostPosted: Wed Nov 21, 2012 4:55 pm     Reply with quote
Thank you for the reply.
Line 44 of pd-led.h is the last line in the code block below. Please Notice that all the individual #FUSES lines before the last one are commented out.
// ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Fuses ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
#FUSES HS                        //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOFCMEN                   //Fail-safe clock monitor disabled
#FUSES NOIESO                    //Internal External Switch Over mode disabled
#FUSES NOPUT                     //No Power Up Timer
#FUSES BROWNOUT                  //Brownout reset
#FUSES BORV27                    //Brownout reset at 2.7V
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES NOLPT1OSC                 //Timer1 configured for higher power operation
#FUSES MCLR                      //Master Clear pin enabled
#FUSES NOSTVREN                  //Stack full/underflow will not cause reset
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST                   //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOPROTECT                 //Code not protected from reading
#FUSES NOCPD                     //No EE protection
#FUSES NOWRT                     //Program memory not write protected
#FUSES NOWRTC                    //configuration not registers write protected
#FUSES NOWRTD                    //Data EEPROM not write protected
#FUSES NOEBTR                    //Memory not protected from table reads
#FUSES HS,NOFCMEN,NOIESO,NOPUT,BROWNOUT,BORV27,NOWDT,NOLPT1OSC,MCLR,NOSTVREN,NOLVP,NOXINST,NOPROTECT,NOCPD,NOWRT,NOWRTC,NOWRTD,NOEBTR
After adding these fuses one by one to the #FUSES line, I found out that the issue is with the fuse NOEBTR at the end.
Coding a second #FUSES Line solved the problem.
#FUSES NOEBTR
Looks like I hit a max character per line limitation some where.
Would the two #FUSES lines work as expected? I mean, Can I split my #FUSES list between two lines?
PostPosted: Wed Nov 21, 2012 6:10 pm     Reply with quote
It 'should' work and obviously would only take you a couple minutes to prove or disprove.There 'might' be differences in compiler versions ?
With the newer PICs that have a LOT of fuses, I now have an #include projectname-fuses.fuz line. Once I have the correct settings for 'fuses' I create the file that gets loaded into the program. It saves me a lot of typing as fuses tend to be 'constant' for a PIC type,makes the 'main' program easier to read(fuses are 'hidden'.but are correct).
I do the same thing for I/O pin usage.A similar file(projectname-pins.pin) that is included which details ALL the I/O pins of the PIC used in the project.Again, makes it easier for me.
hth
jay
Yes, you can have more than one #fuses line. It's OK.
