Debugging 18F25K22
mancio76
Debugging 18F25K22
PostPosted: Tue Nov 13, 2012 10:02 am     Reply with quote
Hello to everybody,
I'm trying debugging PIC18F25K22 bus something seems doesn't work correctly.
I'm using PCWHD 4.137.
To attach to my target, I'm using the ICD3 from Microchip.
The .h file is the following:
#include <18F25K22.h>
#device ICD=TRUE
#device adc=16
#FUSES INTRC                    //Internal RC Osc
#FUSES PRIMARY_SW               //Primary clock can be disabled in software
#FUSES WDT_NOSLEEP              //Watch Dog Timer, disabled during SLEEP
#use delay(int=32000000,RESTART_WDT)
And the .c is:
#include <Test_18F25K22.h>
   setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
   setup_timer_5(T5_DISABLED | T5_DIV_BY_1);
   setup_timer_6(T6_DISABLED,0,1);
      output_low(PIN_C0);
      delay_ms( 50 );
      output_high(PIN_C0);
      delay_ms( 50 );
The problem is that in debugging mode the system seem's doesn't work correctly.
Sometimes it connects to the target and let it running.
If I work with breakpoints or stops the system working, I need to reconnect the ICD to the target, as debugger, to let the system start.
In programming mode seems the system works fine.
Where is the trouble?
Is there anyone can help me?
n-squared
PostPosted: Tue Nov 13, 2012 11:17 pm     Reply with quote
Hi
Try adding the following to the header file:
#FUSES DEBUG
BR
NN
Every solution has a problem.
gpsmikey
PostPosted: Tue Nov 13, 2012 11:58 pm     Reply with quote
Don't know if this affects your problem, but I just got email from CCS informing me that version 4.138 had been released - the interesting line in the update info was
"Updated: PIC18F25K22"
Very Happy
mikey
mikey
mancio76
PostPosted: Wed Nov 14, 2012 2:05 am     Reply with quote
n-squared wrote:
Hi
#FUSES DEBUG
BR
NN
Thank you for the suggestion.
I've correct the header with
#FUSES DEBUG
But still not working properly!
I'm working around on internal clock to understand if the problem can reach from that.
Also, I'm waiting for news coming from version 4.138!
I hope it will resolve the problem!!
mancio76
PostPosted: Wed Nov 14, 2012 3:55 am     Reply with quote
I've update the software to 4.138 and the system was working a little.
Then, I've anailze more in deep my electrical circuit and I've found some components attached to the PGD and PGC data of the ICD3.
I've then isolate the system, removing some resistors and now, finally, the system eneter in debug mode correctly.
That was basically an hardware problem. Maybe mixed a little with the 4.137 software version
Thanks to everyone
