how to combine this program ?
fazreen
PostPosted: Fri Nov 09, 2012 5:32 am     Reply with quote
1. someone help me how to combine this two program to be a single program...
2. help me to join the program tx and rx in one program only
this is my tx program
#include <18F4550.h>                   // PIC18F4550 HEADER FILE
#fuses PUT, HS, NOWDT, NOLVP, NOBROWNOUT,     // EXTERNAL CLOCK, NO WATCH DOG TIMER, NO LOW VOLTAGE PROGRAMMING
#use delay (clock=20M)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, bits=8, parity=N, errors )                  // 4 MHZ CRYSTAL
#define BUTTON1        PIN_B0               // PRESET BUTTON 1
#define BUTTON2        PIN_B1               // PRESET BUTTON 2
#define LED1        PIN_B6               // LED 1
#define LED2        PIN_B7               // LED 2
void main ()
set_tris_b(0x01);                // SET ALL PORT 0-b3 AS INPUT b4-b7 OUTPUT
//set_tris_d(0x00);
//set_tris_c(0x80);             // SET ALL PORT d AS OUTPUT PORT(0b 0000 0000)
output_b(0x00);
while(true)
   putc('g');
   putc('y');
and this my rx program
void main ()
//set_tris_b(0x01);                // SET ALL PORT 0-b3 AS INPUT b4-b7 OUTPUT
//set_tris_d(0x00);
//output_b(0x00);
char data;
while(true)
data = getc();
switch(data)
case 'g':output_high(PIN_B6);
         output_low(PIN_B7);
case 'y':output_low(PIN_B6);
         output_high(PIN_B7);
default:output_low(PIN_B6);
        output_low(PIN_B7);
Mike Walne
PostPosted: Fri Nov 09, 2012 7:14 am     Reply with quote
Rather depends on what you're trying to achieve.
The CCS example EX_STR shows how to rx and tx in succession.
If you want to interleave tx & rx you could try EX_SISR which does RS232 interrupts
Mike
EDIT If you don't like the idea of using interrupts, you can loop round, polling for characters then keys.
juanodiy
PostPosted: Mon Nov 12, 2012 2:07 am     Reply with quote
well, so many things you can do, if you are using rs232 i suppose you want to connect to a PC or something, so for join the programs one solution can be:
if(kbhit)
x=getc();
switch(x)
         output_low(PIN_B7);
        output_low(PIN_B7);
Mike Walne
PostPosted: Mon Nov 12, 2012 11:29 am     Reply with quote
Your tx code is a loop sending out a "g" then a "y" at 500ms intervals.
Your rx code is looking for "g" to turn ports one way, and a "y" to turn the other.
So with your combined code you could connect rx to tx.
Is this what you want?
1) With the rx-tx connection the ports will toggle at 500ms intervals.
2) Without the rx-tx connection the toggling will stop.
Mike
