rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
| #FAST_IO for certain pins |
Posted: Mon Sep 22, 2014 5:48 am |
Hello
I would like to ask you this:
How can I tell the compiler to produce a TRIS direction code only for some pins? Let say we have PORT A with 8 pins form A0 to A7. I want a fast reaction from pin A0 when I set it's state. For the rest 6 pins (A1-A7) I want the compiler to generate a TRIS direction code.
When I read the manual, its written:
| Quote: | Syntax:
#USE FAST_IO (port)
Elements:
port is A, B, C, D, E, F, G, H, J or ALL |
In other words I can adjust the compiler settings only to generate a TRIS direction code for the entire port, not pin by pin. BUT the next directive
#USE FIXED_IO (port_outputs=pin, pin?) is able to handle pin by pin.
So if I set the code for PORTA this way:
| Code: | #USE FAST_IO (A)
#USE FIXED_IO (a_outputs=PIN_A1,PIN_A2, PIN_A3,PIN_A4,PIN_A5,PIN_A6,PIN_A7) |
Does it mean that I will have PIN_A0 as fast I/O? _________________ A person who never made a mistake never tried anything new. |
Posted: Mon Sep 22, 2014 3:23 pm |
No, because only the last directive takes effect. The fixed_io cancels
the fast_io. And fixed_io writes to the whole TRIS register every time
anyway. |
rikotech8
Posted: Tue Sep 23, 2014 6:30 am |
10x _________________ A person who never made a mistake never tried anything new. |
Posted: Tue Sep 23, 2014 10:04 am |
in my work , deciding to declare FAST_IO depends
on how a PORT will be used.
in specific - if speed MATTERS - such as accessing a byte wide SRAM chip's
data pins- ONLY FAST_IO makes sense, since a single unmasked instruction
"does it all". the rest of the time , default CCS "smart" / on the fly TRISIO
is much simpler. pick one or the other and you will be happy.
The other case where fast_io is helpful is where you never, ever anywhere in your code change TRIS, though this might be a CCS version dependent optimization.
Then set TRIS at the top of main() and forget it. |
