Transceiver MRF89X
waranet
Transceiver MRF89X
PostPosted: Mon Jan 31, 2011 10:32 am     Reply with quote
Has anybody did some test with the transceiver from Microchip MRF89x, I'm looking for a C code to check performances and maybe use it in my next RF projects.
Your help will be welcome.
regards
JP
Itronica
PostPosted: Thu Feb 16, 2012 8:15 am     Reply with quote
Good morning, found some examples? I'm also looking for a base with CCS but I have not yet found. thanks
bkamen
PostPosted: Thu Feb 16, 2012 12:10 pm     Reply with quote
Microchip has their Application Software library with some examples I believe.
You should look there. Won't compile under CCS (yet) but will at least give you an idea of what to do.
in_nursery
PostPosted: Thu Oct 25, 2012 9:30 am     Reply with quote
Has anybody worked on that in CCS environment?
Where can I find some example code to show me how to make it work?
Thanks in advance.
bkamen
PostPosted: Thu Oct 25, 2012 9:36 am     Reply with quote
Not for the 89... but I did make a 49 work with CCS...
It's a different chip in some important ways though.
Did you download the example drivers from Microchip yet?
-Ben
in_nursery
PostPosted: Thu Oct 25, 2012 10:29 am     Reply with quote
Ok it's better for me
I just bought the MRF49XA evaluation daughter board.
I download the AN1252.zip from microchip.
in_nursery
PostPosted: Tue Oct 30, 2012 8:04 am     Reply with quote
hi all
I have trouble to translante into CCS this part of code from Microchip C18 v3.04 source code for MRF49XA
C part
#if defined(__18CXX)
    #pragma interrupt HighISR
    void HighISR(void)
#elif defined(__dsPIC30F__) || defined(__dsPIC33F__) || defined(__PIC24F__) || defined(__PIC24H__)
    void _ISRFAST __attribute__((interrupt, auto_psv)) _INT2Interrupt(void)
#endif
    if( RFIE && RFIF )
        nCS = 0;
        if( SPI_SDI == 1 )
            BYTE RxPacketPtr;
            BYTE tmpPacketLen;
            WORD counter;
            // There is data in RX FIFO
            nCS = 1;
            nFSEL = 0;                   // FIFO selected
            tmpPacketLen = SPIRead();
            if( tmpPacketLen >= PAYLOAD_LEN || tmpPacketLen == 0 || hasPacket )
IGNORE_HERE:
                nFSEL = 1;                          // bad packet len received
                RegisterSet(PMCREG);                // turn off the transmitter and receiver
                RegisterSet(FIFORSTREG);            // reset FIFO
                RegisterSet(GENCREG);               // disable FIFO, TX_latch
                RegisterSet(GENCREG | 0x0040);      // enable FIFO
                RegisterSet(PMCREG | 0x0080);       // turn on receiver
                RegisterSet(FIFORSTREG | 0x0002);   // FIFO synchron latch re-enabled
                goto RETURN_HERE;
            RxPacketLen = tmpPacketLen;
            RLED = 1;
            nFSEL = 1;
            RxPacketPtr = 0;
            counter = 0;
                if( counter++ == 0xFFFF )
                    goto IGNORE_HERE;
                else if( FINT == 1)
                    nFSEL = 0;
                    counter = 0;
                    RxPacket[RxPacketPtr++] = SPIRead();
                    if( RxPacketPtr >= RxPacketLen )
                        WORD received_crc;
                        WORD calculated_crc;
                        BYTE i;
                        nFSEL = 1;
                        RLED = 0;
                        RxPacketLen -= 2;       // do not count CRC
                        received_crc = ((WORD)RxPacket[RxPacketLen+1]) + (((WORD)RxPacket[RxPacketLen]) << 8);
                        calculated_crc = CRC16((BYTE *)RxPacket, RxPacketLen);
                        if( received_crc != calculated_crc )
                            RxPacketPtr = 0;
                            RxPacketLen = 0;
                            goto IGNORE_HERE;
                        hasPacket = TRUE;
                        goto RETURN_HERE;
                    nFSEL = 1;
        else            // read the rest of the interrupts
            SPIRead();
            nCS = 1;
RETURN_HERE:
        RFIF = 0;
H part
#define RFIE INTCON3bits.INT3IE
#define RFIF INTCON3bits.INT3IF
thanks for your help
in_nursery
PostPosted: Tue Oct 30, 2012 1:05 pm     Reply with quote
No SPI read function working
whats wrong
#include <18F87J11.h>
//#     DIRECTIVES AU COMPILATEUR
#fuses HS       //Osc Externe
#fuses NOWDT    // No WDT
//#fuses XINST    // Extended Instruction set not support
#use delay(clock=10000000, restart_wdt) // inclure procédure de délais (delay_ms() et delay_us())
#use rs232( baud=19200, parity=n, xmit=PIN_C6, rcv=PIN_C7, bits=8 )
//#use RS232(BAUD=2400, UART1) // interface série
 * Accès direct à certains registres
 * Position des pins.
// PORT A
//#define PIN_   PIN_A0   //
//#define PIN_   PIN_A1   //
//#define PIN_   PIN_A2   //
//#define PIN_   PIN_A3   //
//#define PIN_   PIN_A4   //
#define PIN_BUTTON2      PIN_A5   // PIN_A5  button 2, active low input
//#define PIN_   PIN_A6   //
//#define PIN_   PIN_A7   //
// PORT B
#define PIN_BUTTON1      PIN_B0  // PIN_B0  button 1, active low input
//#define PIN_   PIN_B1   //
//#define PIN_   PIN_B2   //
#define PIN_nIRQ         PIN_B3   // PIN_B3  MRF49XA interrupt
#define PIN_FINT         PIN_B4   // PIN_B4
#define PIN_nRES       PIN_B5   // PIN_B5  MRF49XA reset
//#define PIN_   PIN_B6   //
//#define PIN_   PIN_B7   //
// PORT C
#define PIN_SPI_SDO      PIN_C0   // PIN_C5  SDO
//#define PIN_   PIN_C1   //
#define PIN_nCS         PIN_C2   // PIN_C2  chip select
#define PIN_SPI_SCK      PIN_C3   // PIN_C3  SPI clock
#define PIN_SPI_SDI      PIN_C4   // PIN_C4  SDI
//#define PIN_    PIN_C5   //
//#define PIN_   PIN_C6   //
//#define PIN_   PIN_C7   //
// PORT D
#define PIN_TLED         PIN_D0   // #define TLED        LATDbits.LATD0        // PIN_D0
#define PIN_RLED         PIN_D1   // #define RLED        LATDbits.LATD1       // PIN_D1
//#define PIN_   PIN_D2   //
//#define PIN_   PIN_D3   //
//#define PIN_   PIN_D4   //
//#define PIN_    PIN_D5   //
//#define PIN_   PIN_D6   //
//#define PIN_   PIN_D7   //
// PORT E
//#define PIN_   PIN_E0   //
//#define PIN_   PIN_E1   //
//#define PIN_   PIN_E2   //
#define PIN_nFSEL      PIN_E3   //PIN_E3  fifo select, active low output
//#define PIN_   PIN_E4   //
//#define PIN_    PIN_E5   //
//#define PIN_   PIN_E6   //
//#define PIN_   PIN_E7   //
// MRF49XA selction de la BAND et configuration
//#define BAND_915
//#define BAND_868
#define BAND_434
#define XTAL_LD_CAP 0x0003                      // crystal load 10pF
#if  defined(BAND_434)
   #define FREQ_Band   0x0010   //434MHz
    #define CFSREG        0xA640    // Center Frequency: 434MHz
#elif  defined(BAND_868)
      #define FREQ_Band     0x0020    //868MHz
      #define CFSREG        0xA640    // Center Frequency: 868MHz
#elif  defined(BAND_915)
      #define FREQ_Band     0x0030    //915MHz
     #define CFSREG     0xA7D0    // Center Frequency: 915.000MHz
#endif
 #define GENCREG        (0x8000 | XTAL_LD_CAP |FREQ_Band)
 #define AFCCREG                 0xC4F7
 #define TXCREG                  0x9850          // Deviation: 75kHz
 #define TXBREG                  0xB800
 #define RXCREG                  0x9481          // BW 200KHz, LNA gain 0dB, RSSI -97dBm
 #define FIFORSTREG              0xCA81
 #define DRVSREG                 0xC623          // Data Rate:9579Baud
 #define PMCREG                  0x8201
 #define NODATA              0
 #define DATA_RECEIVED       1
 #define PACKET_RECEIVED      2
 #define PAYLOAD_MAX        4
 #define RX_PACKET_SIZE      10
 #define PAYLOAD_LEN 40                          // the maximum payload size
 #define PACKET_LEN  PAYLOAD_LEN + 2
//#    DÉCLARATION DES VARIABLES (globales)
int16 tableau[34];
 * BYTE SPIRead(void)
 * Overview:
 *              This function read one byte from the SPI interface.
 *              This function use bit-bang to access the SPI port, so
 *              any digital I/O pins can access MRF49XA transceiver
 *              SPI interface
 * PreCondition:
 *              MRF49XA transceiver has been configured properly
 * Input:       None
 * Output:
 *          BYTE    One byte of data received from the SPI interface
 * Side Effects:    None
SPIRead(void)
        int8 i;
        int16 data;
      data=0;
        output_low(PIN_SPI_SDO);
        output_low(PIN_SPI_SCK);
        for(i = 0; i < 8; i++)
            data = (data << 1) | input(PIN_SPI_SDI);
            output_high(PIN_SPI_SCK);
        return data;
 * void RegisterSet(WORD setting)
 * Overview:
 *              This function access the control register of MRF49XA.
 *              The register address and the register settings are
 *              the input
 * PreCondition:
 *              None
 * Input:
 *          WORD    setting     The address of the register and its
 *                              corresponding settings
 * Output:  None
 * Side Effects:    Register settings have been modified
void RegisterSet(int16 setting){
    output_low(PIN_nCS);
    SPI_Write(setting >> 8);
    SPI_Write(setting);
    output_high(PIN_nCS);
 * void BoardInit( void )
 * Overview:        This function configures the board. This routine
 *                  needs to be called before the function to
 *                  initialize demo board
 * PreCondition:    None
 * Input:           None
 * Output:          None
 * Side Effects:    Board is initialized for demo
void BoardInit(void)
    // enable RF INT
  //  INTCON2bits.INTEDG3 = 0;
 //   RFIF = 0;
  //  RFIE = 1;
    output_high(PIN_nRES);           // no reset
    output_high(PIN_nCS);            // nCS inactive
    output_high(PIN_nFSEL);          // nFSEL inactive
    // blink LEDs on start up
    output_high(PIN_TLED);
    delay_ms(50);
    output_high(PIN_RLED);;
    delay_ms(50);
    output_low(PIN_TLED);
    delay_ms(50);
    output_low(PIN_RLED);;
    delay_ms(50);
 * void MRF49XAInit(void)
 * Overview:
 *              This functions initialize the MRF49XA transceiver
 * Input:           None
 * Output:          None
    // configuring the MRF49XA radio
 //   RFIE = 0;
    RegisterSet(FIFORSTREG | 0x0002);       // enable synchron latch
    RegisterSet(AFCCREG);
    RegisterSet(CFSREG);
    RegisterSet(DRVSREG);
    RegisterSet(RXCREG);
    RegisterSet(TXCREG);
    // antenna tuning on startup
    RegisterSet(PMCREG | 0x0020);           // turn on the transmitter
    delay_ms(5);                            // wait for oscillator to stablize
    // end of antenna tuning
    RegisterSet(PMCREG | 0x0080);           // turn off transmitter, turn on receiver
    RegisterSet(GENCREG | 0x0040);          // enable the FIFO
    RegisterSet(0x0000);                // read status byte (read ITs)
  //  RFIE = 1;
 * Fonction principale
void main() {
      // Configuration des registres
   // Setup SPI
    setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_4);
      // Initialiser les variables
      // Boucle principale
   int8 My8bitVar;
   int8 i;
    BYTE phrase_order = 0;
    BYTE line_order = 0;
    BYTE SleepMode = 2;
    BoardInit();
//    ConsoleInit();
     MRF49XAInit();
    Printf("\r\n*****************************************************");
    Printf("\r\n                 MRF49XA Demo Program");
    #if defined(BAND_915)
        Printf("\r\n  Frequency Band:      915MHz");
        Printf("\r\n  Frequency Band:      868MHz");
    #elif defined(BAND_434)
        Printf("\r\n  Frequency Band:      434MHz");
    #endif
    Printf("\r\n       Data Rate:      9600bps");
    Printf("\r\nDemo Instruction:      1. Power On the Other Device");
    Printf("\r\n                       2. Press Button 1 (RB0) to cycle");
    Printf("\r\n                          power states of transceiver");
    Printf("\r\n                       3. Press Button 2 (RA5) on other");
    Printf("\r\n                          device continuously to receive");
    Printf("\r\n                          transmitted data");
    Printf("\r\n\r\n");
   while(1) {
    if( input(PIN_BUTTON1) == 0 )
            while(input(PIN_BUTTON1) == 0);
            switch(SleepMode)
                case 0:
                    RegisterSet(PMCREG | 0x0008);           // switch on oscillator
                    Printf("\r\nMRF49XA wakes up to idle mode");
                    SleepMode++;
                case 1:
                    RegisterSet(GENCREG | 0x0040 );
                    Printf("\r\nMRF49XA set to receive mode\r\n");
                    SleepMode++;
                case 2:
                    RegisterSet(FIFORSTREG);                // turn off FIFO
                    RegisterSet(PMCREG);                    // turn off both receiver and transmitter
                   output_high(PIN_nFSEL); //  nFSEL = 1;
                      output_low(PIN_nCS); // nCS = 0;
                    spi_write(0);   //SPIWrite(0);
                     output_high(PIN_nCS);  //nCS = 1;                            // reset all non latched interrupts
                    Printf("\r\nMRF49XA goes to sleep now");
                    SleepMode = 0;
                default:
 // if received any packet, display it
    if( input(PIN_BUTTON2) == 0 )
      while(input(PIN_BUTTON2) == 0);
      int8 index;
         int8 i;
       for(index=0; index<33; index++) {
            output_low(PIN_nFSEL);
         tableau[index] = spi_read();
      //   My8bitVar=0xB2;
         for(i = 0; i < sizeof(tableau); i++)
           putc(tableau[i]);
       //   putc(My8bitVar);
bkamen
PostPosted: Tue Oct 30, 2012 1:18 pm     Reply with quote
you need to understand that Microchip's libraries are written to use Microchip's compilers (like C18, C30 and C32).
SPI_Write is not a built in CCS function but a function in Microchip's compilers (or possibly hand written in code elsewhere in the project).
You will need to learn to identify and alter incompatible code from Microchip's library to make it work with CCS.
-Ben
in_nursery
PostPosted: Tue Oct 30, 2012 1:44 pm     Reply with quote
SPI_Write is a built in CCS function.
I don't understand your comment.
bkamen
PostPosted: Tue Oct 30, 2012 2:54 pm     Reply with quote
sorry, I'm so used to spi_xfer...
check spi_read() to make sure in the assy it waits for the buffer to empty before continuing to where you release nCS.
If it does not - you'll need to put in an operation to do that otherwise you raise the nCS flag while in the middle of receiving the desired byte.
Do you have an oscilloscope? those are always super helpful here.
Additionally, if you're going to use hardware SPI (setup_spi only works on hardware MSSP's), make sure the pins you're using for SCK, SDI and SDO are hardware allocated pins. (I didn't check the datasheet for your PIC)
-Ben
in_nursery
PostPosted: Fri Nov 02, 2012 6:03 am     Reply with quote
Hi
I stop trying to translate from C18 to ccs.
I rewrote everything and this time it's work fine, very nice chip...
thanks
ezflyr
PostPosted: Fri Nov 02, 2012 9:18 am     Reply with quote
You code will probably help someone just like you, so you should consider
posting it in the code library!
Cheers,
John
