joseph
| Pwm frequency problem |
Posted: Wed Oct 31, 2012 10:50 am |
I working on pwm system and I have a problem. I try to understand some things about the pwm frequency:
By computing, I should have 3.311 kHz but I see 6.5khz with a scope.
Where is the mistake?
Thanks in advance
#include <18F2520.h>
#FUSES NOWDT,INTRC_IO
#use delay(internal=4000000)
void init();
void main (void)
init();
set_pwm1_duty(20);
for(;;){}
void init()
setup_timer_2(T2_DIV_BY_1, 150, 2);
set_timer2(1);
setup_ccp1(ccp_pwm);
Mike Walne
Posted: Wed Oct 31, 2012 11:55 am |
No. I get 6.623kHz.
The timer2 is clocked at oscillator/4 = 1MHz.
You're then telling timer2 to reset after 151 clocks that's 1^6/151 = 6623Hz.
Then you're asking for interrupts at 6623/2 = 3311Hz.
It's all in the CCS manual.
Mike
EDIT Don't forget the tolerance on the internal clock when measuring with 'scope etc! |
Posted: Wed Oct 31, 2012 9:37 pm |
| Quote: | setup_timer_2(T2_DIV_BY_1, 150, 2);
The last parameter of 2 is only used with the #int_timer2 interrupt.
You don't have an interrupt routine, so it has no effect on your program.
Links on PWM:
http://www.ccsinfo.com/forum/viewtopic.php?t=45968&start=1 |
