ccsload Command Line Parameters
RickDaystorm
PostPosted: Mon Oct 29, 2012 9:06 pm     Reply with quote
Does anyone know where I could find a list of all available command line parameters for the ccsload.exe application?
More specifically, I'd like to modify the line in the compiler's "Program Chip" button so that ccsload.exe first erases the entire chip then loads in the active HEX file.
Rick
PostPosted: Tue Oct 30, 2012 12:29 pm     Reply with quote
Well, you should look in the Help file for CCSLoad.
c:\program files\picc\ccsload.chm
Then go to the Contents tab and click on the section for "Command Line Use".
