Read eeprom lost 2 address
nguyentuandang
PostPosted: Tue Oct 30, 2012 11:33 am     Reply with quote
#include <16f877a.h>
#fuses NOWDT,PUT,HS,NOPROTECT
#use delay(clock=12000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
main(){
int8 e,g,f;
g=0;
e=0;
while(g<50)
   write_eeprom(50+g,71);
   g++;
while(e<50)
   f=read_eeprom (50+e);
   putc(f);
   e++;
I use vb6 for rs232 communication.
When i used this code, in vb6 only show 48 character and lost 2 chacracters. I don't know why. Someone help me please.
PostPosted: Tue Oct 30, 2012 11:56 am     Reply with quote
This is the same old problem. You should not let your program fall off
the end of main(). That's because CCS puts a hidden sleep instruction there.
Here is the situation:
#asm  SLEEP  #endasm    // Hidden sleep instruction
When the PIC executes the SLEEP instruction, it shuts down the oscillator.
This means the UART will stop running. The UART has a buffer that can
hold one character. Also, the output shift register in the UART can hold
another character. When the UART is shut down by the SLEEP instruction
those two characters will not be shifted out. You will lose two characters
at the end of the message.
To fix this, you need to add a continuous loop at the end of the program:
while(1);   // Add this line here
gpsmikey
PostPosted: Tue Oct 30, 2012 2:40 pm     Reply with quote
Hey thanks PCM - I normally don't escape from main(), but I wasn't aware of that tidbit about the sleep instruction. See if I can remember it - handy to know anyway.
mikey
mikey
nguyentuandang
thanks
PostPosted: Tue Oct 30, 2012 8:55 pm     Reply with quote
Thanks so much:))
