dspic30f4011 pwm module
Mahdi
PostPosted: Tue Oct 23, 2012 1:44 am     Reply with quote
hi
I want to setup 6 channel pwm module on dspic30f4011.
I need a sample code.
Its code is not like with a pic16 and pic18f series.
Please help me.
thanks
PostPosted: Tue Oct 23, 2012 3:28 am     Reply with quote
Be aware, that Microchip are very misleading in what they call 'channels'. They use 'channel' as a PWM output pin. This PIC _only_ has three PWM timing generators, and can only output three PWM signals at a time. The three signals can drive six pins.
Look at the example "EX_MOTOR_PWM.c", which shows how to setup this PWM.
In your case only pairs 1 to 3 can be used.
