Can't setup_spi2(mode) for Pic18f4431 ?
tidushuu
PostPosted: Wed Oct 17, 2012 10:38 am     Reply with quote
Using PCWHD 4.104 , I saw datasheet of Pic18f4431 and it have 2 SPI port, but when i try to setup_spi2, the compiler show error.
My test code is here
#include <18F4431.h>
#device adc=8
#use delay(clock=20M)
setup_spi2(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
And pin_out of 18f4431
http://circuits.datasheetdir.com/19/PIC18F4431-pinout.jpg
PostPosted: Wed Oct 17, 2012 12:08 pm     Reply with quote
It doesn't have two SPI channels. It has alternate pins. Look at the
SSPMX configuration bit in the 18F4431 data sheet. It selects between
the normal pins and the alternate pins for SPI.
