Hi, I want to create animation affect on GLCD, but I can't because picture be blink when change. I set delay_ms(100) between pictures but the screen still blinks.
So that, is there any way to solve this problem ??
I'm using GLCD (128x64) with PIC18F4550.
Posted: Sat Oct 13, 2012 2:08 pm
If you want more speed, then you should write bytes to the GLCD instead
of pixels. Arrange your data so that you write blocks of bytes to the LCD.
Prepare the data in advance, in tables (arrays), and just write the table
to the GLCD.
