Bit shifting
Prefekt
Bit shifting
PostPosted: Fri Oct 05, 2012 2:41 pm     Reply with quote
I'm confused...
I have a char array
a[0] = '0';
a[1] = '1';
now I would like to set the output with the a[1] value...
for example:
a[1] = 3;
out = 00000100;
or
a[1]  = 7;
out = 01000000;
I try:
out =1;
out = out << a[1];
output_d(out);
not working..
anybody an idea?
thanks
PostPosted: Fri Oct 05, 2012 4:54 pm     Reply with quote
You want to convert a bit number to a bitmask. Use a lookup table.
With the following table placed above main(), you can now put in code
in main() to get the bitmask. Use a number from 0 to 7 as the index
to get the bitmask for bit number 0 to 7. For bit 0, you will get 0x01,
and for bit 7 you will get 0x80, etc.
int8 const bitmask_table[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
To use your incoming numbers as index values for this table, you will
need to convert them from ASCII characters to binary digits in the range
from 0 to 7.
This post may have some hints.
http://www.ccsinfo.com/forum/viewtopic.php?t=48590&start=3
