12F683 interrupt problem
edi
PostPosted: Sun Sep 30, 2012 1:56 am     Reply with quote
PIC12F683
Compiler - 4.120
Tool - MPLAB ICD2
The code suppose to blink the LED when the TACT push button is pressed.
All other time stay in sleep.
1. The INT does not work, any idea why?
2. The code start to run the first 8 test blinks only with the ICD2 pluged, but not when the board is stand alone, why?
#include <12F683.h>
#fuses MCLR,INTRC_IO,PUT,NOWDT,NOPROTECT,NOBROWNOUT
#byte OSCCAL = 0x80 // 0x80 is the center frequency
#byte porta=0x05
#byte trisa=0x85
#bit LED1 = porta.5
#bit TACT = porta.4 // Push Button connect to GP4 and GND
void init()
   porta = 0b111111;   // | LED  | TACT |    |    |    |    |
   trisa = 0b011111;   // | OUT  | IN   | IN | IN | IN | IN |
   PORT_A_PULLUPS(0b110000); // Pull up on GP5 and 4
   LED1 = 0;                  //LED ON
   delay_ms(10);                      // Built-in delay function
   LED1 = 1;
   delay_ms(50);                      // Built-in delay function
#INT_EXT
void ext_isr() {
   if (!TACT)
      LED1 = 0;                  //LED ON
      LED1 = 1;
      delay_ms(100);                      // Built-in delay function
   int8 loop;
   init();
   ext_int_edge(H_TO_L);      // init interrupt triggering for button press
   enable_interrupts(INT_EXT_H2L);// turn on interrupts
   for (loop=0; loop<8; loop++) // blink LED 8 times at start up
      LED1 = 0;                  //LED ON
      LED1 = 1;
   sleep();
PostPosted: Sun Sep 30, 2012 2:43 am     Reply with quote
The obvious problem is that INT_EXT, is on pin A2, not A4. This is where _reading the data sheet_ is vital.
edi
PostPosted: Sun Sep 30, 2012 6:37 am     Reply with quote
Changed to INT_RA and it works thanks
