dsPIC and graphic HDM64GS12 128x64 Display Problem
an1234
PostPosted: Wed Jan 30, 2013 12:44 am     Reply with quote
I am using a ds30F4013 PIC with HDM64GS12 128x64 Display with the CCS examples HDM64GS12.c and graphics.c
The Display works fine but in some case the PIC makes a reset and the will program starts new.
The PIC will be reset when I call a graphic function which delete a pixel on the display.
For Example glcd_rect(45, 18, 69, 25, YES, OFF); IF last argument is "Off" the PIC makes the reset.
So I can only set pixel and I can't clear pixel.
I have the same problen when I want to set a single pixel glcd_pixel(10, 10, OFF)
Do you have an ideas?
Display Connector:
DATA is connected to PORT B (0:7) output_b(data);
RB8-RB12 is not connected
GLCD_CS1 PIN_D0 // Chip Selection 1
GLCD_CS2 PIN_D1 // Chip Selection 2
GLCD_DI PIN_D2 // Data or Instruction input
GLCD_RW PIN_D3 // Read/Write
GLCD_E PIN_C13 // Enable
GLCD_RST PIN_C14 // Reset
This is the program:
#include <30f4013.h>
#FUSES NOWDT, NOPROTECT, NODEBUG, NOBROWNOUT, XT, NOPUT
#use delay(clock=20MHz , crystal)
#use rs232(baud=38400, UART1, ERRORS, stream = PC)
#define FAST_GLCD   // Try commenting this out to see the differences
#define LARGE_LCD
#include <HDM64GS12.c>
#include <graphics.c>
#include <math.h>
//#include "STRING.H"
      char BT[15] = "Bluetooth";
      char clear[21];
         char valueOnGlcd[10]="****";
   long io;
   printf("CAN GLCD BoX1\r\n");
   strcpy(clear,"                   *");
   printf("CAN GLCD BoX2\r\n");
   delay_ms(200);
   glcd_init(ON);
   printf("GLCD Init Ready\r\n");
          io++;
      sprintf(valueOnGlcd, "%lu", io *1250);       // buffer in text unwandel
      glcd_rect(4, 25, 20, 40, YES,OFF);   // Alten Wert Löschen
      glcd_text57(5, 30, valueOnGlcd, 1, ON);      // Neuen Wert schreiben
      lcd_update();
many thanks for your reply
an1234
PostPosted: Wed Jan 30, 2013 1:15 pm     Reply with quote
I found the problem.
The reset is caused by Bit_clear(*p,y%8) in HDM64GS12.c
I changed it into *p =& y%8 and it works Fine.
