ENC28J60 TCP/IP connection
rikotech8
PostPosted: Sun Jul 08, 2012 6:31 am     Reply with quote
Hi everyone!Sorry about my bad English Embarassed !
I'm interested by pic and ethernet communication.
I'm on my way to attempt to build project with pic18fxxx and ENC28J60 http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en022889 by SPI between them.
The reason I'm not going to use PIC18F97J60(which has build in ethernet controller) is that I haven't needed libraries for "TCP/IP.c" That's why I prefer to use conventional pic whit SPI and separate controller (ENC28J60).
My question is: Have someone ever created such a project?
If the answer is yes, I would appreciate whatever information. Very Happy
Thank you!
jgschmidt
PostPosted: Mon Jul 09, 2012 10:45 am     Reply with quote
You will need a TCP/IP library.
I know of two options:
1) get the free Microchip TCP/IP library and free student version of the C18 compiler. You can get lots of good support from the Microchip forums. You can also see an example project with hardware and software and guides for how to adapt the libraries to your particular hardware on my website (see below). This is for a PIC24 but can apply to PIC18 as well.
2) get the latest version of the CCS PCH compiler. This costs money. It includes a TCP/IP library. It also includes the manuals for the CCS development boards which provide circuits and examples for how to get started with TCP/IP. You will get good support from the CCS forums.
Be sure to use the correct forum for the path you choose.
A warning: embedded TCP/IP is not easy. The TCP/IP library contains thousands of lines of code. Any small error in hardware or software will result in failure.
Good luck.
Jürgen
www.jgscraft.com
rikotech8
re
PostPosted: Wed Jul 11, 2012 3:29 am     Reply with quote
How can I get
some links would be very helpful.
Thanks!
jgschmidt
PostPosted: Wed Jul 11, 2012 8:42 am     Reply with quote
I will send you a private message.
Jürgen
www.jgscraft.com
davekieu
PostPosted: Sat Sep 29, 2012 1:36 am     Reply with quote
can you send to me too ?
Many Thanks.
