Changing slave address with jumper configuration
rudy
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sat Sep 15, 2012 1:04 pm     Reply with quote
Hi.
I am planning to start a new development, probably, It will have one 16F877A as master and three others processors as slave over I2C line, and one RTC and one 256kb I2C memory also.
My question is if there is any way to configure the slaves addresses using two or three configurations jumpers instead of use something like this:
#include <16f877a.h>
#fuses HS,PUT,WDT,PROTECT,NOBROWNOUT,NOLVP,NOCPD
#use delay(clock=20000000, RESTART_WDT)
#use I2C (SLAVE, ADDRESS=0x12, SDA=PIN_B4, SCL= PIN_B6, SLOW, RESTART_WDT)
Thank you for help me up;
Regards.
PostPosted: Sat Sep 15, 2012 2:31 pm     Reply with quote
Download the CCS manual:
Do a search of the PDF for the word: slave
What's the first function that you find ? That's the one you want.
rudy
PostPosted: Sat Sep 15, 2012 3:44 pm     Reply with quote
What a team!!!!!
Great.
Thanks a lot.
