internal EEPROM read/write and Code Protection CPD WRTD
cformer
PostPosted: Tue Sep 18, 2012 12:22 pm     Reply with quote
I'm trying to use the internal data EEPROM to store a serial number.
I use the write_eeprom() and read_eeprom() commands to read and write bytes and it works fine.
However, when I clear the CPD and WRTD configuration bits (0=write protection enabled), the program cannot write or read as before.
According to the Microchip datasheet ( PIC18F86K22_39960d.pdf ) this should still work though:
"Data EEPROM memory has its own code-protect bits in
the Configuration Words. External read and write
operations are disabled if code protection is enabled.
The microcontroller itself can both read and write to the
internal data EEPROM, regardless of the state of the
code-protect Configuration bit.
Any idea anyone?
PostPosted: Tue Sep 18, 2012 12:36 pm     Reply with quote
Your quote is referring to the CPD config bit. But you are also clearing
(ie, enabling) the WRTD bit. The 18F86K22 data sheet says that WRTD
prevents the PIC from writing to its internal data eeprom:
http://ww1.microchip.com/downloads/en/DeviceDoc/39960d.pdf
28.6.2 DATA EEPROM CODE PROTECTION
The entire data EEPROM is protected from external
reads and writes by two bits: CPD and WRTD. CPD
inhibits external reads and writes of data EEPROM.
WRTD inhibits internal and external writes to data
EEPROM. The CPU can always read data EEPROM
under normal operation, regardless of the protection bit
settings.
cformer
PostPosted: Wed Sep 19, 2012 7:51 am     Reply with quote
Thank you very much PCM programmer!
That fixed it. I hadn't spotted the other paragraph you quoted, and the one I was referring to was not really clear (to me anyway, proven by my misinterpretation).
