Read the input of MCP23S17 - Pic24f
joseph20480
PostPosted: Wed Sep 12, 2012 12:56 pm     Reply with quote
HI,
I'm working on a library for my project and i have a problem...
I'm trying to set the 16 I/O in input mode, and read them but nothing (Mode output no problem).
CCS : 4.128 / Pic 24Fj64GA104
Register and pinout :
//-- MCP23S17 --
#pin_select SCK1OUT   = PIN_C5    // Clock
#pin_select SDI1    = PIN_C3    // Data input
#pin_select SDO1      = PIN_c4   // Data output
#define      mcp_clk   pin_c5
#define      mcp_sdi   pin_c3
#define      mcp_sdo   pin_c4
#define      mcp_cs   pin_a4
#define write_mode   0x40
#define   read_mode   0x41
#define IOCON_reg   0x0A
#define   IODIR_reg   0x00   // Direction register          [ 1=input / 0=output ]
#define   IPOL_reg   0x02   // Input polarity            [ 0= same / 1=opposite ]
#define   GPPU_reg   0x0c   // Pull up resistor register   [ 1=pullup enable / 0=pullup disable ]
#define   GPIO_reg   0x12   // General purpose IO register
#define   OLAT_reg   0x14   // Output latch register      [ 1=logic_high / 0=logic_low ]
#define GPINTEN_reg   0x04    // Interrupt register         [ 1=enable / 0=disable]
My init function
void mcp_init()
   setup_spi(SPI_MASTER |SPI_L_TO_H | SPI_CLK_DIV_6); // Spi n°1 - Max 10Mhz
      mcp_write(IOCON_reg,0x40,0x40);    // config registre mode de communiquation
   // PortA & PortB en output
         //mcp_write(IODIR_reg,0x00,0x00);
      //mcp_write(OLAT_reg,0x00,0x00);
      //mcp_write(GPPU_reg,0x00,0x00);
      //mcp_write(GPIO_reg,0xff,0xff);
   // PortA & PortB en input
      mcp_write(IODIR_reg,0xFF,0xFF);      // PortA et PortB en entrees
      mcp_write(IPOL_reg,0x00,0x00);      // valeur identique a l'etat de l'input
      mcp_write(GPINTEN_reg,0x00,0x00);   // Pas d'interruption
My Write / read function
void mcp_write(int8 adresse,int8 data_1,int8 data_2)
   output_low(mcp_cs);
      spi_write(write_mode);
      spi_write(adresse);
      spi_write(data_1);
      spi_write(data_2);
   output_high(mcp_cs);
void mcp_read(int8 adresse)
   int8 data1;
   int8 data2;
   output_low(mcp_cs);
      spi_write(read_mode);
      spi_write(adresse);
      data1=spi_read(0);
      data2=spi_read(0);
For read my input, I call the the function mcp_read() with GPIO_reg parameter.
If someone sees a terrible mistake !?
PostPosted: Wed Sep 12, 2012 4:37 pm     Reply with quote
Look at the SPI mode #define statements for the PIC24FJ-series by FvM
at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38491&start=34
Look at Figure 2-5 in the MCP23S17 data sheet, on page 32:
http://ww1.microchip.com/downloads/en/DeviceDoc/21952b.pdf
It shows that SPI mode 0,0 or mode 1,1 can be used with this chip.
I don't know what mode you have in your setup_spi() statement. But
you need to fix it, according to the two links I gave above.
