DS1307 SQW/OUT pin generate pulses at 1 second intervals
bolubeyi
PostPosted: Wed Sep 05, 2012 9:14 am     Reply with quote
Hi, I use ds1307 and ccs c. I want to generate pulses at 1 second intervals from ds1307 SQW/OUT - Square Wave/Output pins. How can I do this? How do I set ds1307?
PostPosted: Wed Sep 05, 2012 10:20 am     Reply with quote
Here's the way I do it...
Sorry I don't know where this function came from but it does work...
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // point to Control Register
i2c_write(0x10); // Enable squarewave output pin
i2c_stop();
The second last line does the job. If you read the DS1307 datasheet, it'll also explain how to set for other interrupt rates.
hth
jay
