Get GSM response using interrupts
lan ahmad
PostPosted: Fri Aug 31, 2012 9:26 am     Reply with quote
Hello guys, I want to ask something. I hope you all can help. I want to display "OK" from gsm modem to lcd. This is my coding. Can someone help me ? I can't get the response.
GSM modem: SIMCOM
#include <16f876a.h>
#device adc=8
#use delay (clock=20000000)
#fuses hs,nolvp,nowdt,noprotect,nobrownout
#use rs232(baud=9600, bits=8, xmit=pin_C6, rcv=pin_C7, parity=n, stream=GSM)
#byte porta=5
#byte portb=6
#byte portc=7
#include "flex_lcd.c"
#include <string.h>
int GET_OK(Stop_Search);
int TEST_AT();
volatile int  counter_search=0;            //counter to traverse the array
volatile int  counter_read=0;             //counter to fill the array
volatile Char Recieve_String[70];   //buffer for incoming data
#INT_RDA
void SerialInt()
   Recieve_String[counter_read]=getchar();
   counter_read++;
   if(counter_read==69)counter_read=0;
SET_TRIS_A( 0x00 );
SET_TRIS_B( 0x00 );
OUTPUT_B(0X00);
SET_TRIS_C( 0x00 );
enable_interrupts(INT_RDA);  // enable RDA interrupts
enable_interrupts(GLOBAL);   // enable global ints
lcd_putc("\fget OK");
output_high(PIN_C4);    //led on
output_low(PIN_C4);    //led off
output_low(PIN_C4);
if(TEST_AT())
lcd_putc("\fComplete");
int TEST_AT()
   counter_read=0;
   printf("AT\n\r");                //send command
   while(counter_read<=8)
   output_low(PIN_C4);
   counter_read=0;
   if(GET_OK(0X0A))
      return(1);
   else return(0);
   counter_search=0;
   while((Recieve_String[counter_search]!='O')&&(counter_search<Stop_Search))   //check buffer until an 'O' is found or 10 chars have been checked.
      counter_search++;     //obvious
   if((Recieve_String[counter_search]=='O')&&(Recieve_String[counter_search+1]=='K'))  //check for a 'K' after the 'O'
      counter_search=0;
      return(1);              //function returns true
   return(0);
   counter_search=0;
Gabriel
PostPosted: Mon Sep 03, 2012 9:08 am     Reply with quote
You need to test your LDC individually to rule out display hardware problems.
Then, you need to test your connections between PIC and CELL.
Remember that in rs232 comm, there is a DTE and DCE.
Both PIC and CELL are DCEs... so you need to swap TX/RX lines.
Remove the TRIS settings... I did that in the past to "save power" ... its not necessary at this moment in your project.
THE MOST IMPORTANT PART HERE IS:
int TEST_AT()
   counter_read=0;
   while(counter_read<=8)  //<------------------THIS PART
   output_low(PIN_C4);
   counter_read=0;
   if(GET_OK(0X0A))
      return(1);
   else return(0);
If your modem does not respond to the "AT" command with more than 8 chars you will be stuck inside that loop.
Try this better (my code was specific to my modem):
int TEST_AT()
   counter_read=0;
   delay_ms(500);             //<------------------CHANGE TO THIS
   output_low(PIN_C4);
   counter_read=0;
   if(GET_OK(0X0A))
      return(1);
   else return(0);
I hope that helps.
G.
CCS PCM 5.078 & CCS PCH 5.093
