Debug / trace macro
gribas
Debug / trace macro
PostPosted: Thu Aug 30, 2012 11:20 am     Reply with quote
Is there a better way to print debug info? I wasn't able to hide the stream information inside the macro (RS232_STREAM), so I end up with this:
#define DEBUG 1
#define TRACE(x) \
        do { if (DEBUG) fprintf x ; } while (0)
   TRACE((RS232_STREAM,"Test %d %s \r\n",1,"..."));
Regards,
PostPosted: Thu Aug 30, 2012 1:39 pm     Reply with quote
This thread may have some tips:
http://www.ccsinfo.com/forum/viewtopic.php?t=47206
gribas
PostPosted: Thu Aug 30, 2012 2:53 pm     Reply with quote
Thanks for the info! After reading that thread I came up with some alternatives that seem to work:
If you want to be able to switch to/from debug mode (debug will be present in production code)
#define TRACE(x) \
         do { if (debug_var) fprintf x ; } while (0)
  debug_var = 1;
  TRACE((DBG,"Debug information: a=%u, b=%u",
                         variable_name_a,
                         variable_name_b));
  debug_var = 0;
  TRACE((DBG,"No Output"));
If you want to remove all debug info from production code
#ifdef DEBUG
    #define TRACE(x)   fprintf x
#else
    #define TRACE(x)
  TRACE((DBG,"Debug information: a=%u, b=%u %s",
                         variable_name_a,
                         variable_name_b,
                         "\n"));
If you want to create switchable debug blocks
#define _D if(debug_var)
  debug_var = 1;
  _D printf("This is a debug statement");
  _D {
     a += 10;
     b += 11;
If you want to create debug blocks that will go away when in production
#ifdef DEBUG
    #define _D if (1)
#else
    #define _D if (0)
  _D {
     a += 10; printf("Test");
