programming EEPROM
rikotech8
programming EEPROM
PostPosted: Thu Aug 23, 2012 11:30 am     Reply with quote
Hi!
Is that possible to write into a EEPROM memory (not program flash memory) directly from a programmer
(MPLAB-PicKit3 in this case), not by running the program. I want to write certain bytes at certain location into an EEPROM along with programming the chip. If it is possible, i'd like to know how.
Thanks in advance!
ezflyr
PostPosted: Thu Aug 23, 2012 1:17 pm     Reply with quote
Yes, it's possible. Look at the #ROM directive in the CCS Compiler manual.
John
PostPosted: Thu Aug 23, 2012 2:44 pm     Reply with quote
and the command:
getenv("EEPROM_ADDRESS")
will give the address needed on any chip (assuming you have a reasonably recent compiler), so you don't have to work out 'where' the EEPROM is in the programming space.
rikotech8
PostPosted: Fri Aug 24, 2012 3:41 am     Reply with quote
Thanks for reply, and how can I read the written data into a ROM. Is that function going to work: read_program_eeprom( )?
PostPosted: Fri Aug 24, 2012 3:52 am     Reply with quote
No.
READ_EEPROM, and WRITE_EEPROM, are the functions to talk to the data EEPROM.
read_program_eeprom, reads the code memory (hence 'program'), instead.
spilz
PostPosted: Tue Oct 09, 2012 3:01 pm     Reply with quote
I don't understand how to use getenv("EEPROM_ADDRESS") and #ROM at the same time
do they have to be in "main" or is it out the code?
thanks
PostPosted: Tue Oct 09, 2012 3:18 pm     Reply with quote
This thread has an example of using #rom with getenv for the data eeprom:
http://www.ccsinfo.com/forum/viewtopic.php?t=43607&start=2
spilz
PostPosted: Tue Oct 09, 2012 3:47 pm     Reply with quote
thanks for your quick reply,
I try to add it :
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000,restart_wdt)
#ROM getenv("EEPROM_ADDRESS") = {0,0}
but when I try to compile (V4.065) I have the error :
Invalid ORG range
do you have an idea about this problem?
PostPosted: Tue Oct 09, 2012 4:02 pm     Reply with quote
It doesn't work with that version. It's too old. Use this line instead:
#rom int8 0xF00000 = {0,0}
