micro_debugger
24FJ..Buffered RS232 still not working - any help please |
Posted: Tue Aug 21, 2012 4:23 pm |
I have started to write a simple program for buffered RS232 communication on the 24FJ64GB106. The non buffered procedure is working well, however the buffered routines are not working. Could you please make a short lookup and suggest me where I'm wrong. Thank you in advance,
Best Regards
#include <24FJ64GB106.h>
//#device ICD=TRUE
#build(stack=512)
#fuses HS,NOWDT,PR
#use delay(clock=12000000,RESTART_WDT)
#pin_select U1TX = PIN_B6
#pin_select U1RX = PIN_B7
#use rs232(UART1,baud=9600,parity=N,bits=8, STREAM=RADIO)
#pin_select U2TX = PIN_G6
#pin_select U2RX = PIN_G7
#use rs232(UART2,baud=9600,parity=N,bits=8, STREAM=RS232)
// defined crystal is 12 Mhz fro the following calculated RTC timmer interrupt
#define RTCC_TIME_20_ms 35405 //20ms
#define RTCC_TIME_10_ms 50470 //10ms
#define RTCC_TIME_5_ms 58003 //5ms
#define RTCC_TIME_2_5ms 61769 //2.5ms
#define RTCC_TIME_2ms 62523 //2ms
#define TX_RADIO_BUFFER_SIZE 192
volatile unsigned int8 tx_radio_buffer[TX_RADIO_BUFFER_SIZE];
volatile unsigned int8 tx_radio_next_in;
volatile unsigned int8 tx_radio_next_out;
#define TX_RS232_BUFFER_SIZE 192
volatile unsigned int8 tx_rs232_buffer[TX_RS232_BUFFER_SIZE];
volatile unsigned int8 tx_rs232_next_in;
volatile unsigned int8 tx_rs232_next_out;
#define RX_RADIO_BUFFER_SIZE 192
volatile unsigned int8 rx_radio_buffer[RX_RADIO_BUFFER_SIZE];
volatile unsigned int8 rx_radio_next_in;
volatile unsigned int8 rx_radio_next_out;
#define bkbhit_radio (rx_radio_next_in != rx_radio_next_out)
#define RX_RS232_BUFFER_SIZE 192
volatile unsigned int8 rx_rs232_buffer[RX_RS232_BUFFER_SIZE];
volatile unsigned int8 rx_rs232_next_in;
volatile unsigned int8 rx_rs232_next_out;
#define bkbhit_rs232 (rx_rs232_next_in != rx_rs232_next_out)
void LED_SYNC_ON(void)
output_high(PIN_E0);
void LED_SYNC_OFF(void)
output_low(PIN_E0);
/////////////// RADIO SERIAL PORT HANDLER START ///////////////////////
#int_TBE
void TBE_isr(void)
if(tx_radio_next_in!=tx_radio_next_out)
putc(tx_radio_buffer[tx_radio_next_out], RADIO);
tx_radio_next_out=(tx_radio_next_out+1) % TX_RADIO_BUFFER_SIZE;
disable_interrupts(int_tbe);
void bputc_radio(unsigned char c)
short restart;
int ni;
restart=tx_radio_next_in==tx_radio_next_out;
tx_radio_buffer[tx_radio_next_in]=c;
ni=(tx_radio_next_in+1) % TX_RADIO_BUFFER_SIZE;
while(ni==tx_radio_next_out);
tx_radio_next_in=ni;
if(restart)
enable_interrupts(int_tbe);
#INT_RDA
void RDA_isr()
unsigned int8 t;
rx_radio_buffer[rx_radio_next_in] = fgetc(RADIO);
t = rx_radio_next_in;
rx_radio_next_in = (rx_radio_next_in+1) % RX_RADIO_BUFFER_SIZE;
if(rx_radio_next_in == rx_radio_next_out)
rx_radio_next_in=t; // Buffer full !!
int8 bgetc_radio()
unsigned int8 c;
unsigned int8 timeout;
while(!bkbhit_radio && ++timeout<=10)
delay_ms(10);
c = rx_radio_buffer[rx_radio_next_out];
rx_radio_next_out = (rx_radio_next_out+1) % RX_RADIO_BUFFER_SIZE;
return c;
/////////////// RADIO SERIAL PORT HANDLER STOP ///////////////////////
/////////////// RS232 SERIAL PORT HANDLER START ///////////////////////
#int_TBE2
void TBE2_isr(void)
if(tx_rs232_next_in!=tx_rs232_next_out)
putc(tx_rs232_buffer[tx_rs232_next_out], RS232);
tx_rs232_next_out=(tx_rs232_next_out+1) % TX_RS232_BUFFER_SIZE;
disable_interrupts(int_tbe2);
void bputc_rs232(unsigned char c)
short restart;
int ni;
restart=tx_rs232_next_in==tx_rs232_next_out;
tx_rs232_buffer[tx_rs232_next_in]=c;
ni=(tx_rs232_next_in+1) % TX_RS232_BUFFER_SIZE;
while(ni==tx_rs232_next_out);
tx_rs232_next_in=ni;
if(restart)
enable_interrupts(int_tbe2);
#INT_RDA2
void RDA2_isr()
unsigned int8 t;
rx_rs232_buffer[rx_rs232_next_in] = fgetc(RS232);
t = rx_rs232_next_in;
rx_rs232_next_in = (rx_rs232_next_in+1) % RX_RS232_BUFFER_SIZE;
if(rx_rs232_next_in == rx_rs232_next_out)
rx_rs232_next_in=t; // Buffer full !!
int8 bgetc_rs232()
unsigned int8 c;
while(!bkbhit_rs232 && ++timeout<=10)
delay_ms(10);
c = rx_rs232_buffer[rx_rs232_next_out];
rx_rs232_next_out = (rx_rs232_next_out+1) % RX_RS232_BUFFER_SIZE;
return c;
/////////////// RS232 SERIAL PORT HANDLER STOP ///////////////////////
#INT_TIMER1
void timer1_isr()
// set_timer1(TIMER_SET_01); //0.1 sec
// multipier10--;
// if(multipier10==0)
// multipier10=10;
// num_seconds_LED++;
// num_seconds++;
//setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
//set_timer1(TIMER_SET_01); //0.1 sec
//multipier10=10;
tx_radio_next_in = tx_radio_next_out = 0;
tx_rs232_next_in = tx_rs232_next_out = 0;
rx_radio_next_in = rx_radio_next_out = 0;
rx_rs232_next_in = rx_rs232_next_out = 0;
//setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
enable_interrupts(INT_RDA);
enable_interrupts(INT_TBE);
enable_interrupts(INT_RDA2);
enable_interrupts(INT_TBE2);
LED_SYNC_OFF();
fprintf(radio,"%x", 0xAA);
fprintf(rs232, "%x", 0xAA);
delay_ms(50);
LED_SYNC_ON();
delay_ms(50);
LED_SYNC_OFF();
printf(bgetc_radio,"%x", 0xAA);
printf(bgetc_rs232, "%x", 0xAA);
delay_ms(50);
LED_SYNC_ON();
delay_ms(50);
Last edited by micro_debugger on Wed Aug 22, 2012 4:36 pm; edited 1 time in total |
Posted: Wed Aug 22, 2012 1:26 am |
The obvious big mistake, is you are talking to the wrong function.
_putc_ (and bputc for the buffer), is the function to 'put' data. You are printing to 'bgetc', the function to get data.....
micro_debugger
Posted: Wed Aug 22, 2012 11:38 am |
Hi Ttelmah,
Thank you so much for your indication. I corrected it as alo other small mistakes I have found. However it is still not working. I have used it 100 times in the 8 bit processors, but it is my first impression with 16bit. May be you can see it again, please, ansd have any idea. 4 eyes is much more than 2 eyes :-)
My best regards
here is the corrected code with your and some mine corrections
#device ICD=3
#build(stack=512)
#ZERO_RAM
#fuses HS,NOWDT,PR
//#fuses ICSP2
#define TX_RADIO_BUFFER_SIZE 64
#define RX_RADIO_BUFFER_SIZE 64
#define TX_RS232_BUFFER_SIZE 64
#define RX_RS232_BUFFER_SIZE 64
output_low(PIN_E0);
#int_TBE
void TBE_isr(void)
fputc(tx_radio_buffer[tx_radio_next_out], RADIO);
short restart;
unsigned int8 ni;
if(restart)
#INT_RDA
void RDA_isr()
unsigned int8 t;
int8 bgetc_radio()
unsigned int8 c;
delay_ms(10);
return c;
#int_TBE2
void TBE2_isr(void)
fputc(tx_rs232_buffer[tx_rs232_next_out], RS232);
short restart;
unsigned int8 ni;
if(restart)
#INT_RDA2
void RDA2_isr()
unsigned int8 t;
int8 bgetc_rs232()
unsigned int8 c;
delay_ms(10);
return c;
#INT_TIMER1
void timer1_isr()
// multipier10--;
// multipier10=10;
// num_seconds++;
//multipier10=10;
LED_SYNC_OFF();
delay_ms(50);
LED_SYNC_ON();
delay_ms(50);
LED_SYNC_OFF();
printf(bputc_radio,"A");
printf(bputc_rs232, "A");
delay_ms(50);
LED_SYNC_ON();
delay_ms(50);
