		| View previous topic :: View next topic   |
			Neo2a
				| SD card problem dsPIC33FJ128GP710A |
				 Posted: Tue Aug 21, 2012 3:09 am     |
				Dear programmers,
I have a problem with uSD card handling.
The program is initialized a SD card well.
After it write a file ("cmc.txt")
Answer on serial line is "OK" but the card is still empty.
Please help me what's wrong in my code?
http://juropnet.hu/~ipucz/Project.zip
Thank you!
Best regards
Steve |
			ezflyr
				 Posted: Tue Aug 21, 2012 7:31 am     |
Post your code here. No one is interested to go out to a random Hungarian website to download your .zip file. Don't make helping you to solve your problem more difficult than it has to be - if you do, your plea for help will just be ignored by a majority of the forum users.
I also noticed that you asked almost exactly the same question back in May. You had one response asking for a copy of your schematic in PDF format (because your posted schematic was in a proprietary format), but you never responded to the request. Are you really serious about solving this problem?
John |
				 Posted: Tue Aug 21, 2012 8:37 am     |
				What is the size of your SD card? The CCS library only supports standard SD cards up to 4Gb, not the High Capacity cards.
Perhaps your card has a Master Boot Record? The CCS driver often has problems in handling these. Try formatting the card in a photo camera.
Have a look at the Code Library section of this forum you will find other SD drivers there. Also a few bugfixes have been posted for the CCS library: http://www.ccsinfo.com/forum/viewtopic.php?t=43402
Before posting your answers on this forum, check the first sticky post in this forum. It gives some guidelines for posting questions here. |
			Neo2a
			Neo2a
				| All modification is done |
				 Posted: Wed Aug 22, 2012 2:34 am     |
				Modifications in mmcsd.c
Search for uint32_t g_mmcsdBufferAddress;
and add under it:
uint32_t g_mmcsdPartitionOffset;
Next, just before the "mmcsd_init" function add a new function:
void mmcsd_check_part(uint16_t off)
if (g_mmcsd_buffer[off + 0] == 0x80)
// active partition
uint8_t t;
t = g_mmcsd_buffer[off + 4];
if (t == 0x04 || t == 0x06 || t == 0x0B)
// FAT16 or FAT32 partition
g_mmcsdPartitionOffset = make32(
g_mmcsd_buffer[off + 11], g_mmcsd_buffer[off + 10],
g_mmcsd_buffer[off + 9], g_mmcsd_buffer[off + 8]) * MMCSD_MAX_BLOCK_SIZE;
In the "mmcsd_init" function, right after the line:
r1 = mmcsd_load_buffer();
Add the lines:
g_mmcsdPartitionOffset = 0;
mmcsd_check_part(0x1EE);
mmcsd_check_part(0x1DE);
mmcsd_check_part(0x1CE);
mmcsd_check_part(0x1BE);
Finally, in the function "mmcsd_move_buffer", after the line:
new_block = new_addr - (new_addr % MMCSD_MAX_BLOCK_SIZE);
Add the line:
new_block += g_mmcsdPartitionOffset;
The CCS "fat.c" functions "get_next_addr" and "get_prev_addr" do not correctly handle cluster transitions. The following are corrected functions, so replace the function with the following code:
signed int get_next_addr(int32* my_addr)
int32 temp;
#ifdef FAT32
int32 c;
#else
int16 c;
#endif
// check to make sure that the next iteration will give us a contiguous address
temp = *my_addr + 1;
if((temp > Data_Start) && ((temp - Data_Start) % Bytes_Per_Cluster == 0))
// convert the current address into the address of where information about
//  the address is stored in the FAT, and put this value into the current address
c = addr_to_cluster(temp - 1);
if(get_next_cluster(&c) == EOF)
return EOF;
if (c >=
#ifdef FAT32
0x0FFFFFF8
#else
0xFFF8
#endif
return EOF;
temp = cluster_to_addr(c);
*my_addr = temp;
return GOODEC;
Further, get_prev_addr() needs to be updated:
signed int8 get_prev_addr(int32* my_addr)
int32 temp;
#ifdef FAT32
int32 c;
#else
int16 c;
#endif
temp = *my_addr;
// if we're trying to go backwards one entry from the beginning of the root,
//  we won't be able to...
if(temp <= Root_Dir)
return GOODEC;
if((temp >= Data_Start) && ((temp - Data_Start) % Bytes_Per_Cluster == 0))
c = addr_to_cluster(temp);
if(get_prev_cluster(&c) == EOF)
return EOF;
temp = cluster_to_addr(c) + Bytes_Per_Cluster;
*my_addr = temp - 1;
return GOODEC;
In fat_init() function search for the following lines
#ifdef FAT32
Data_Start = Bytes_Per_Cluster + Root_Dir;
#else // FAT16
and replace it with the following code (i.e. remove "Bytes_Per_Cluster +"):
#ifdef FAT32
Data_Start = Root_Dir;
#else // FAT16
And finally, get_short_file_name() needs to be replaced with the following code:
signed int get_short_file_name(int32 file_entry_addr, char sname[], int8 type)
int
buf,
i,
j = 0;
// one short file name has, at the most, 11 characters
for(i = 0; i < 11; ++i)
// read in a character
if(mmcsd_read_data(i + file_entry_addr, 1, &buf) != GOODEC)
return EOF;
// convert the character
if(buf != ' ')
if (i == 8 && type != 0x10) sname[j++] = '.';
sname[j++] = tolower(buf);
if (sname[j - 1] == '.') --j;
sname[j] = '\0';
return GOODEC;
} | 	  [/code] |
			Neo2a
				| After all modification |
				 Posted: Wed Aug 22, 2012 2:36 am     |
				After all modification implemented into the code
The fat.c
#ifndef FAT_PIC_C
#define FAT_PIC_C
Code deleted.
Sorry, modified code is still CCS code.  Rule #10 applies:
10. Don't post the CCS example code or drivers, or ask for such code and drivers.
A list of mods is OK, but not the complete driver file.
Forum Rules:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
			Neo2a
				| MMCSD content |
				 Posted: Wed Aug 22, 2012 2:40 am     |
				After modifications implemented the
mmcsd.c content is
#ifndef FAT_PIC_C
#define FAT_PIC_C
#include <ctype.h>
#include <string.h>
#case
/// Useful Defines ///
/// Define your FAT type here ///
#define FAT16
//#define FAT32
/// For faster single-file writing, uncomment this line below ///
//#define FAST_FAT
/// Everything else ///
#define MAX_FILE_NAME_LENGTH 0x20  // the maximum length of a file name for our FAT, including /0 terminator
#define STREAM_BUF_SIZE 0x20       // how big the FILE buffer is. 0x20 is optimal
#define EOF -1
#define GOODEC 0
#define fatpos_t int32
#define SEEK_CUR 0
#define SEEK_END 1
#define SEEK_SET 2
/// Global Variables ///
int16
   Bytes_Per_Cluster,   // number of addressable bytes per cluster
   FAT_Start;           // when the first FAT begins
int32
   Data_Start,          // when data starts
   FAT_Length,          // the length of one FAT
   Next_Free_Clust,     // where the next free cluster is
   Root_Dir;            // when the root directory starts
enum filetype
   Data_File,  // the stream is pointing to a binary, data file
   Directory,  // the stream is pointing to a directory
   None        // the stream isn't currently pointing to anything
enum ioflags
   Closed = 0x00,
   Read = 0x01,
   Write = 0x02,
   Append = 0x04,
   Binary = 0x08,
   EOF_Reached = 0x10,
   Read_Error = 0x20,
   Write_Error = 0x40,
   File_Not_Found = 0x80
struct iobuf
   fatpos_t
      Bytes_Until_EOF,     // how many bytes until the stream's end of file
      Cur_Char,            // the current byte that the stream is pointing at
      Entry_Addr,          // the entry address of the file that is associated with the stream
      Parent_Start_Addr,   // the parent's start adddress of the file that is associated with the stream
      Size,                // the size of the file that is associated with the stream
      Start_Addr;          // the beginning of the data in the file that is associated with the stream
   enum filetype File_Type;   // the type of file that is associated with the stream
   enum ioflags Flags;        // any associated input/output flag
   int Buf[STREAM_BUF_SIZE];  // this is a buffer so that during fatputc() or fatgetc()
                              //  the media won't have to be read at every character
typedef struct iobuf FILE;
/// Function Prototypes ///
/// Standard C Functions ///
signed int fatopen(char fname[], char mode[], FILE* stream);
signed int fatreopen(char fname[], char mode[], FILE* stream);
signed int fatclose(FILE* stream);
signed int fatgetc(FILE* stream);
signed int fatputc(int ch, FILE* stream);
char* fatgets(char* str, int num, FILE* stream);
signed int fatputs(char* str, FILE* stream);
signed int fatprintf(FILE* stream);
signed int fatgetpos(FILE* stream, fatpos_t* position);
signed int fatsetpos(FILE* stream, fatpos_t* position);
signed int fatseek(FILE* stream, int32 offset, int origin);
signed int fateof(FILE* stream);
signed int faterror(FILE* stream);
signed int fatread(void* buffer, int size, int32 num, FILE* stream);
signed int fatwrite(void* buffer, int size, int32 count, FILE* stream );
signed int fatflush(FILE* stream);
signed int remove(char* fname);
void clearerr(FILE* stream);
void rewind(FILE* stream);
fatpos_t fattell(FILE* stream);
/// Non-Standard C Functions ///
signed int rm_file(char fname[]);
signed int rm_dir(char dname[]);
signed int mk_file(char fname[]);
signed int mk_dir(char dname[]);
/// Functions' Utility Functions ///
signed int set_file(char fname[], int attrib, FILE* stream);
signed int get_file_name(int32 file_entry_addr, char name[]);
signed int set_file_name(int32 parent_dir_addr, int32* entry_addr, char name[]);
signed int get_short_file_name(int32 file_entry_addr, char sname[], int type);
signed int make_short_file_name(int32 parent_dir_addr, char fname[], char sname[]);
int long_name_chksum (int* pFcbName);
signed int check_invalid_char(char fname[]);
#ifdef FAT32
signed int get_next_free_cluster(int32* my_cluster);
signed int dealloc_clusters(int32 start_cluster);
signed int alloc_clusters(int32 start_cluster, int32* new_cluster_addr);
signed int clear_cluster(int32 cluster);
signed int write_fat(int32 cluster, int32 data);
#else // FAT16
signed int get_next_free_cluster(int16* my_cluster);
signed int dealloc_clusters(int16 start_cluster);
signed int alloc_clusters(int16 start_cluster, int32* new_cluster_addr);
signed int clear_cluster(int16 cluster);
signed int write_fat(int16 cluster, int16 data);
#endif // #ifdef FAT32
signed int get_next_file(FILE* stream);
signed int get_prev_file(FILE* stream);
signed int get_next_free_addr(int32* my_addr);
signed int get_next_free_entry(int32* start_addr);
signed int get_next_entry(int32* start_addr);
signed int get_prev_entry(int32* start_addr);
signed int read_buffer(FILE* stream, int* val);
signed int write_buffer(FILE* stream, int val);
void fill_entry(char the_entry[], char val, int8 start_ind);
void disp_timestamp(int16 timestamp);
void disp_datestamp(int16 datestamp);
/// Data Utility Functions ///
signed int fat_init();
#ifdef FAT32
signed int get_next_cluster(int32* my_cluster);
signed int get_prev_cluster(int32* my_cluster);
int32 cluster_to_addr(int32 cluster);
int32 addr_to_cluster(int32 addr);
#else // FAT16
signed int get_next_cluster(int16* my_cluster);
signed int get_prev_cluster(int16* my_cluster);
int32 cluster_to_addr(int16 cluster);
int16 addr_to_cluster(int32 addr);
signed int get_next_addr(int32* my_addr);
signed int get_prev_addr(int32* my_addr);
signed int format(int32 DskSize);
/// Debugging Utility Functions ///
signed int disp_folder_contents(char foldername[]);
signed int dump_addr(int32 from, int32 to);
signed int dump_clusters(int32 from, int32 to);
void disp_fat_stats();
signed int fatprintfinfo(FILE* stream);
/// Function Implementations ///
Summary: This will open up a file stream for reading, writing, or appending.
Param fname: The full path of the file to open.
Param mode: The mode to open up the stream into.
             "r" = Read
             "w" = Write
             "a" = Append
             "rb", "wb", "ab" = Read, Write, or Append in Binary mode
Param stream: The stream to open up.
Returns: EOF if there was a problem, GOODEC if everything went okay.
Note: fname must be in the form of /filename.fil for a file in the root directory
       /Directory/filename.fil for a file in a subdirectory of root
       /Directory/Subdirectory/filename.fil and so on...
Note: Standard C will make a file in case a file isn't found,
       however due to recursion this is not possible in CCSC.
   int fname_parse_pos = 1;    // the current index of the fname character
   char target_file[MAX_FILE_NAME_LENGTH];   // temporary buffer to hold names of files
   FILE cur_stream;     // this will   be the stream that will be returned if all goes well
#ifndef FAST_FAT
   int
      depth = 0,              // how many subdirectories deep the file is
      target_file_parse_pos;  // the current index of the target_file character
#endif // #ifndef FAST_FAT
   // set flags
#ifdef FAST_FAT
   switch(mode[0])
      case 'w':
         cur_stream.Flags = Write;
      case 'a':
         cur_stream.Flags = Append;
      default:
         return EOF;
   // start looking for the file, start at root
   cur_stream.Start_Addr = cur_stream.Parent_Start_Addr = Root_Dir;
   while(fname[fname_parse_pos] != '\0')
      target_file[fname_parse_pos - 1] = fname[fname_parse_pos];
      fname_parse_pos += 1;
   target_file[fname_parse_pos] = '\0';
   // find the file inside of its subdirectory
   if(set_file(target_file, 0x20, &cur_stream) != GOODEC)
      cur_stream.Flags |= File_Not_Found;
      *stream = cur_stream;
      return EOF;
   // at this point, we've found the file
   return GOODEC;
#else // NO FAST_FAT
   switch(mode[0])
      case 'r':
         cur_stream.Flags = Read;
      case 'w':
      case 'a':
      default:
         return EOF;
   if(mode[1] == 'b')
      cur_stream.Flags |= Binary;
   // figure out how deep we have to go, count how many '/' we have in the string
      if(fname[fname_parse_pos] == '/')
         depth++;
   // start the fname index at 1 to skip over the '/'
   // open up to the subdirectory, if possible
   while(depth > 0)
      // find the name of our next target directory
      target_file_parse_pos = 0;
      while(fname[fname_parse_pos] != '/')
         // check to make sure that we're not at the end of a poorly formatted string
         if(fname[fname_parse_pos] == '\0')
            return EOF;
         // fill up the buffer and increment the indexes
         target_file[target_file_parse_pos] = fname[fname_parse_pos];
         target_file_parse_pos += 1;
      // increment the fname index one more because it's currently pointing at the '/'
      // tack on a \0 to the end of the target file to terminate the string
      target_file[target_file_parse_pos] = '\0';
      // check to see if the directory exists and open it if possible, otherwise exit because the directory doesn't exist
      if(set_file(target_file, 0x10, &cur_stream) != GOODEC)
         return EOF;
      depth -= 1;
   // check to see if we're trying to open just a directory
      return GOODEC;
   // now that we have the location of the subdirectory that the file is in, attempt to open the file
      return EOF;
   return GOODEC;
#endif // #ifdef FAST_FAT
signed int fatreopen(char fname[], char mode[], FILE* old_stream, FILE* new_stream)
Summary: This will close a stream and then reopen it using new parameters.
             "r" = Read
             "w" = Write
             "a" = Append
Param stream: The stream to close and reopen.
   // close the old stream
   if(fatclose(stream) == EOF)
     return EOF;
   // open the new stream
   if(fatopen(fname, mode, stream) == EOF)
      return EOF;
   return GOODEC;
Summary: Closes a stream and commits any changes done to the file.
Param: The stream to close.
Returns: EOF if there was a problem, 0 if everything went okay.
   int ec = 0;
   int32 first_cluster;
   // commit data back to the stream's entry, if needed
   if((stream->Flags & Write) || (stream->Flags & Append))
      // write the new size of the file
      if(mmcsd_write_data(stream->Entry_Addr + 0x1C, 4, &(stream->Size)) != GOODEC)
         stream->Flags |= Write_Error;
         return EOF;
      // check to see if the first cluster is already linked in the file
      ec += mmcsd_read_data(stream->Entry_Addr + 0x14, 2, (int16*)&first_cluster + 1);
      ec += mmcsd_read_data(stream->Entry_Addr + 0x1A, 2, &first_cluster);
      if(ec != GOODEC)
         stream->Flags |= Read_Error;
         return EOF;
      // write the first cluster to the entry if needed
      if(first_cluster == 0)
         // convert the start address to a cluster number
         first_cluster = addr_to_cluster(stream->Start_Addr);
         ec += mmcsd_write_data(stream->Entry_Addr + 0x14, 2, (int16*)&first_cluster + 1);
         ec += mmcsd_write_data(stream->Entry_Addr + 0x1A, 2, &first_cluster);
         if(ec != GOODEC)
            return EOF;
      // dump the remaining buffer to the card
      if(fatflush(stream) == EOF)
         return EOF;
   // nullify the data
   stream->Cur_Char = 0;
   stream->Entry_Addr = 0;
   stream->Size = 0;
   stream->Start_Addr = 0;
   stream->Flags = 0;
   return 0;
Summary: Gets a character from a stream.
Param: The stream to get a character from.
Returns: The character that was gotten from the stream,
          EOF if the stream has reached the end of the file or doesn't have permissions to read,
   char ch; // character read in
   // check to see if the stream has proper permissions to read
   if(stream->Flags & Read)
      // when the number of bytes until eof hit zero, we know we are at the end of any file
      if(stream->Bytes_Until_EOF == 0)
         stream->Flags |= EOF_Reached;
         return EOF;
      // read in the next byte in the buffer
      if(read_buffer(stream, &ch) == EOF)
         return EOF;
      // a 0x00 will signify the end of a non-binary file
      if((ch == '\0') && !(stream->Flags & Binary))
         return EOF;
      // get the next contiguous address of the stream
      if(get_next_addr(&(stream->Cur_Char)) != GOODEC)
         return EOF;
      // we just got 1 byte closer to the end of the file
      stream->Bytes_Until_EOF -= 1;
      return ch;
   // if the stream doesn't have proper permissions to read, return an EOF
      return EOF;
Summary: Puts a character into a stream.
Param ch: The character to put into the stream.
Param stream: The stream to put a character into.
Returns: The character that was put into the stream,
          EOF if the stream doesn't have permissions to write, or if a problem happened.
   // check to see if the stream has proper permissions to write
   if(((stream->Flags & Write) || (stream->Flags & Append)) && (stream->File_Type == Data_File))
      // if there isn't any space allocated yet, allocate some
      if(stream->Cur_Char < Data_Start)
         if(get_next_free_cluster(&Next_Free_Clust) == EOF)
            return EOF;
#ifdef FAT32
         if(write_fat(Next_Free_Clust, 0x0FFFFFFF) == EOF)
            return EOF;
#else // FAT16
         if(write_fat(Next_Free_Clust, 0xFFFF) == EOF)
            return EOF;
         if(clear_cluster(Next_Free_Clust) == EOF)
            return EOF;
         stream->Cur_Char = stream->Start_Addr = cluster_to_addr(Next_Free_Clust);
      // write the next character to the buffer
      if(write_buffer(stream, ch) == EOF)
         return EOF;
      // get the next address, increment Cur_Char
      if(get_next_addr(&(stream->Cur_Char)) == EOF)
         // write the current buffer to the end of the current cluster
         if(mmcsd_write_data(stream->Cur_Char - STREAM_BUF_SIZE + 1, STREAM_BUF_SIZE, stream->Buf) != GOODEC)
            return EOF;
         // start looking for a new cluster to allocate
         if(alloc_clusters(addr_to_cluster(stream->Cur_Char), &(stream->Cur_Char)) == EOF)
            return EOF;
      // our file just got bigger by 1 byte
      stream->Size += 1;
      return ch;
   // if the stream doesn't have proper permissions to write, return an EOF
      return EOF;
Summary: Reads characters from a stream into a string.
Param str: A pointer to the beginning of the string to put characters into.
Param num: The number of characters to put into the string - 1.
Param stream: The stream to read from.
Returns: A pointer to the most recently added character, or NULL if there was an error.
Note: If a newline is read from the stream, then str will be terminated with a newline.
       If num - 1 or EOF is reached, then str will be null terminated.
   int i;   // counter for loops
   // loop until num - 1
   for(i = 0; i < num - 1; i += 1)
      str[i] = fatgetc(stream);
      if(str[i] == '\n')
         return str;
      if(str[i] == EOF)
   // close off str with a null terminator
   str[i] = '\0';
   return str;
Summary: Writes characters from a string into a stream.
Param str: A pointer to the beginning of the string to write into the stream.
Param stream: The stream to write into.
   int i = 0;   // counter for loops
   // fatputc every character in the stream
   while(str[i] != '\0')
      if(fatputc(str[i], stream) == EOF)
        return EOF;
      i += 1;
   return GOODEC;
Summary: This will print off the entire contents of the stream to the console.
Param: The stream to print off.
Returns: The last character printed off to the console.
   signed int ch; // character read in
   // keep on printf any characters read in as long as we don't run into an end of file or a media error
   do
      ch = fatgetc(stream);
      printf("%c", ch);
   } while(ch != EOF);
   return ch;
Summary: Returns the current position of where the stream is pointing to relative to the beginning of the stream.
Param stream: The stream to get the position of.
Param position: A pointer to a variable put the current position of the pointer into.
Returns: 0 on success.
   *position = stream->Size - stream->Bytes_Until_EOF;
   return 0;
Summary: Sets the current position of where the stream is pointing to in memory relative to the beginning of the stream.
Param stream: The stream to set the position of.
Param position: A pointer the a variable that has the value of the new position.
Returns: 0 on success, or EOF if there was error.
#ifndef FAST_FAT
#ifdef FAT32
   int32 cur_cluster; // the current cluster we're pointing to
#else // FAT16
   int16 cur_cluster; // the current cluster we're pointing to
   int32 i;    // pointer to memory
   // check to see if we want to just rewind the file
   if(*position == 0)
      rewind(stream);
      return GOODEC;
   // this whole process is much different and easier if we're writing or appending at a spot after EOF
   //  this will essentially write null characters to the file from EOF to the desired position
   if(((stream->Flags & Write) || (stream->Flags & Append)) && (stream->Size < *position))
      while(stream->Size < *position)
         if(fatputc('\0', stream) == EOF)
            return EOF;
      return 0;
#ifdef FAST_FAT
   stream->Cur_Char = stream->Start_Addr + *position;
   // figure out how many clusters into the file the position is to be set to
   i = *position / Bytes_Per_Cluster;
   cur_cluster = addr_to_cluster(stream->Start_Addr);
   // head to that cluster
   while(i > 0)
      if(get_next_cluster(&cur_cluster) != GOODEC)
         return EOF;
      i -= 1;
   // head to the correct cluster
   stream->Cur_Char = cluster_to_addr(cur_cluster);
   // now that we're in the correct cluster, tack on the remaining position
   stream->Cur_Char += (*position % Bytes_Per_Cluster);
      // we now need to change how far it is until EOF
      stream->Bytes_Until_EOF = stream->Size - *position;
      if(mmcsd_read_data(stream->Cur_Char, STREAM_BUF_SIZE, stream->Buf) != GOODEC)
         return EOF;
      stream->Size = *position;
   return 0;
Summary: This will set the position of the file stream according to the input. The EOF flag will also be cleared.
Param offset: How many bytes relative of origin the file stream position will be set.
Param origin: This will be one of 3 values...
               SEEK_CUR: Set position relative to the current stream position.
               SEEK_END: Set position relative to the end of the stream.
               SEEK_SET: Set position relative to the beginning of the stream.
   int32 myoffset;   // since fatsetpos requires a pointer to a variable, we need this here
   switch(origin)
      case SEEK_CUR:
         myoffset = stream->Cur_Char + offset;
         if(fatsetpos(stream, &myoffset) != 0)
            return EOF;
      case SEEK_END:
         myoffset = stream->Size - offset;
            return EOF;
      case SEEK_SET:
         myoffset = offset;
            return EOF;
      default:
         return EOF;
   // clear the EOF flag
   stream->Flags &= 0xEF;
   return GOODEC;
Summary: Determines whether or not the stream is at the end of the file.
Param: The stream to query for EOF.
Returns: A non-zero value if the file is at EOF,
          0 if the file is not at EOF.
   return stream->Flags & EOF_Reached;
Summary: Fills up an array with data from a stream.
Param buffer: A pointer to the beginning of an array of any type.
Param size: How many bytes each element in the array is.
Param num: How many elements to fill in the array.
Returns: How many values were written to the array.
   int32 i; // counter for loop
   // fill up every byte
   for(i = 0; i < (num * size); i += 1)
      buffer[i] = fatgetc(stream);
   return i;
Summary: Fills up a stream with data from an array
Param num: How many elements to write to the stream.
Param stream: The stream to write to.
Returns: How many values were written to the stream.
   // write every byte
   for(i = 0; i < (count * (int32)size); i += 1)
      if(fatputc(buffer[i], stream) == EOF)
         return EOF;
   return i;
Summary: Flushes the buffer of a given stream.
Param: The stream to flush the buffer of.
   // check to see if we have a buffer
      // check to see if we need to flush the buffer
      if(stream->Cur_Char % STREAM_BUF_SIZE == 0)
         // flush the buffer to the card
         if(mmcsd_write_data(stream->Cur_Char - STREAM_BUF_SIZE, STREAM_BUF_SIZE, stream->Buf) != GOODEC)
            return EOF;
         //  we need to make sure that the buffer gets flushed into the proper location, hence all this weird % math
         if(mmcsd_write_data(stream->Cur_Char - (stream->Cur_Char % STREAM_BUF_SIZE), STREAM_BUF_SIZE, stream->Buf) != GOODEC)
            return EOF;
      return(mmcsd_flush_buffer());
   return 0;
Summary: Removes a file from disk.
Param: The full path of the file to remove.
Note: This function does not work for removing directories, use rm_dir instead.
   if(rm_file(fname) == EOF)
       return EOF;
   return 0;
Summary: Checks for an error in a given stream.
Param: The stream to check for an error in.
Returns: A non-zero value of there is an error in the stream,
          0 if there is no error in the stream
   return stream->Flags & 0xF0;
Summary: Clears off all error in a given stream.
Param: The stream to clear off the errors in.
Returns: Nothing.
   stream->Flags &= 0x0F;
Summary: Sets the stream to point back to the beginning of a file.
Param: The stream to rewind.
Returns: Nothing.
   // set the stream back to the beginning
   stream->Cur_Char = stream->Start_Addr;
   stream->Bytes_Until_EOF = stream->Size;
Param: The stream to return the position of.
Returns: The position of where the stream is pointing to relative to the beginning of the stream, or 0 if there was a problem.
   fatpos_t retval;
   if(fatgetpos(stream, &retval) != 0)
      return 0;
   return retval;
Summary: Deletes a file.
Param: The full path of the file to delete.
Returns: GOODEC if everything went okay, EOF if there was a problem.
   int
      order,
      ulinked_entry = 0xE5; // 0xE5 is put into the file's entry to indicate unlinking
   int32 i;
   char mode[] = "r";        // r is the safest mode to remove files with
   FILE stream;              // the stream that we'll be working with
   // attempt to open the stream
   if(fatopen(fname, mode, &stream) == EOF)
      return EOF;
   // we need to un-link the file's clusters from the FAT if there are clusters allocated
   if(stream.Start_Addr > Root_Dir)
      if(dealloc_clusters(addr_to_cluster(stream.Start_Addr)) == EOF)
         return EOF;
   // get rid of the first entry
   i = stream.Entry_Addr;
   if(mmcsd_write_data(i, 1, &ulinked_entry) == EOF)
      return EOF;
   // check to see if there is a long file name
   get_prev_entry(&i);
   if(mmcsd_read_data(i + 11, 1, &order) == EOF)
      return EOF;
   // get rid of all of the long file name entries if they're there
   while(order == 0x0F)
         return EOF;
      if(get_prev_entry(&i) == EOF)
         return EOF;
         return EOF;
   if(fatclose(&stream) == EOF)
      return EOF;
   return GOODEC;
Summary: Deletes a directory.
Param: The full path of the directory to delete.
Note: dname must be in the form of /Dirname/ for a directory in the root directory
       /Dirname/Subdirname/ for a directory in a subdirectory of root and so on...
Note: This function cannot remove all of the files
       and subdirectories of the directory. Manually remove all subdirectories
       and files before calling this command.
   if(fatopen(dname, mode, &stream) == EOF)
      return EOF;
   // jump over the . and .. entries in the directory
   stream.Entry_Addr = stream.Start_Addr + 64;
   // check to make sure that there isn't stuff in this directory
   if(get_next_file(&stream) != EOF)
      return EOF;
   // since removing files is a lot like removing directories, we
   //  can just call rm_file
   if(rm_file(dname) == EOF)
      return EOF;
   return GOODEC;
Summary: Creates a file.
Param: The full path of the file to create.
Note: This function will not create directories if parent directories don't exist.
   char
      filename[MAX_FILE_NAME_LENGTH],   // the file name we're trying to make
      mode[] = "r";                     // reading is the safest mode to work in
   int
      buf,               // buffer to hold values
      entire_entry[0x20],// entire first entry
      filename_pos = 0,  // the current parse position of the file name we're trying to create
      fname_pos;         // the current parse position of the input the the function
   // attempt to open up to the directory
   if(fatopen(fname, mode, &stream) == GOODEC)
      return EOF; // we shouldn't get an GOODEC back from fatopen()
   // check to see if the file is already there.
   if(!(stream.Flags & File_Not_Found))
      return EOF;
   // make a file name
   fname_pos = strrchr(fname, '/') - fname + 1;
   while((fname[fname_pos] != '\0') && (filename_pos < MAX_FILE_NAME_LENGTH))
      filename[filename_pos] = fname[fname_pos];
      fname_pos += 1;
      filename_pos += 1;
   filename[filename_pos] = '\0';
   // write the name
   if(set_file_name(stream.Start_Addr, &i, filename) == EOF)
      return EOF;
   // throw in some values in the file's first entry
   for(buf = 0; buf < 0x20; buf += 1)
      entire_entry[buf] = 0;
   // this is a file
   entire_entry[0x0B] = 0x20;
   // read what set_file_name gave us for the short name
   if(mmcsd_read_data(i, 11, entire_entry) != GOODEC)
      return EOF;
   // write the entry
   if(mmcsd_write_data(i, 0x20, entire_entry) != GOODEC)
      return EOF;
   return GOODEC;
Summary: Creates a directory.
Param: The full path of the directory to create.
   char
      dirname[MAX_FILE_NAME_LENGTH],    // the directory name we're trying to make
      entire_entry[0x20],               // used to hold the link entries (. and ..) to the directory and its parent
   int
      dirname_pos = 0,   // the current parse position of the directory name we're trying to create
      dname_pos,         // the current parse position of the input the the function
      j;                 // counter for loops
   if(fatopen(dname, mode, &stream) == GOODEC)
   // check to see if the directory is already there.
      return EOF;
   // make the directory name
   dname_pos = strrchr(dname, '/') - dname;
   dname[dname_pos] = '\0';
   dname_pos = strrchr(dname, '/') - dname + 1;
   while((dname[dname_pos] != '\0') && (dirname_pos < MAX_FILE_NAME_LENGTH))
      dirname[dirname_pos] = dname[dname_pos];
      dname_pos += 1;
      dirname_pos += 1;
   dirname[dirname_pos] = '\0';
   dname[dname_pos] = '/';
   // write the file's name
   if(set_file_name(stream.Start_Addr, &i, dirname) == EOF)
      return EOF;
   // find and allocate an open cluster
      return EOF;
      return EOF;
#ifdef FAT32
      return EOF;
#else // FAT16
      return EOF;
   for(j = 0; j < 0x20; j += 1)
      entire_entry[j] = 0;
   // this is a directory
   entire_entry[0x0B] = 0x10;
   entire_entry[0x1A] = make8(Next_Free_Clust, 0);
   entire_entry[0x1B] = make8(Next_Free_Clust, 1);
#ifdef FAT32
   entire_entry[0x14] = make8(Next_Free_Clust, 2);
   entire_entry[0x15] = make8(Next_Free_Clust, 3);
      return EOF;
   // write the file's first entry
      return EOF;
   // make the two links that point to the directory and the directory's parent
   i = cluster_to_addr(Next_Free_Clust);
   // put in the first link that points to the directory itself
      if(j < 0x01)
         entire_entry[j] = '.';
      else if(j < 0x0B)
         entire_entry[j] = 0x20;
      else if(j == 0x0B)
         entire_entry[j] = 0x10;
         entire_entry[j] = 0x00;
#ifdef FAT32
      return EOF;
   for(j = 0; j < 0x0C; j += 1)
      if(j < 0x02)
      else if(j < 0x0B)
   if(stream.Parent_Start_Addr == Root_Dir)
      entire_entry[0x14] = 0x00;
      entire_entry[0x15] = 0x00;
      entire_entry[0x1A] = 0x00;
      entire_entry[0x1B] = 0x00;
      entire_entry[0x1A] = make8(addr_to_cluster(stream.Parent_Start_Addr), 0);
      entire_entry[0x1B] = make8(addr_to_cluster(stream.Parent_Start_Addr), 1);
#ifdef FAT32
      entire_entry[0x14] = make8(addr_to_cluster(stream.Parent_Start_Addr), 2);
      entire_entry[0x15] = make8(addr_to_cluster(stream.Parent_Start_Addr), 3);
   if(mmcsd_write_data(i + 0x20, 0x20, entire_entry) != GOODEC)
      return EOF;
   return GOODEC;
/// NOTE: A library user should not need to use any of the functions in this section ///
Summary: This will set the stream to point to the specified file.
Param fname: The file name to search for.
Param attrib: The file attributes to search for. 0x10 is a directory, 0x20 is a file.
Param stream: The stream to set.
Note: The stream has to be pointing to the parent directory's start address when coming in to this function.
   int
      cur_attrib,    // the attribute of the most recently read entry
      cur_state,     // the state of the most recently read entry
      ec = 0;        // error checking byte
#ifndef FAST_FAT
   char name_buffer[MAX_FILE_NAME_LENGTH];   // buffer to hold in the most recently read in name
   // set the memory pointer to the parent start address
   i = stream->Start_Addr;
   // search for the name of our target file inside of the parent directory
   do
      // read the state and the attribute of the current entry
      ec += mmcsd_read_data(i, 1, &cur_state);
      ec += mmcsd_read_data(i + 0x0B, 1, &cur_attrib);
      if(ec != GOODEC)
         return EOF;
       // check to make sure that this entry exists and the entry is the type we're looking for
      if((cur_state != 0xE5) && (cur_attrib == attrib))
#ifndef FAST_FAT
         // get the long file name of the current entry
         if(get_file_name(i, name_buffer) == EOF)
            return EOF;
         // if the target entry and the long file name are equal, strcmp will return a zero
         if(strcmp(fname, name_buffer) == 0)
            // we have found our target entry, set the current entry and break out of this function
            // set stream's parent address
            stream->Parent_Start_Addr = stream->Start_Addr;
            ec += mmcsd_read_data(i + 0x1C, 4, &(stream->Size));
            // stream->Start_Addr is going to temporarily have a cluster number
            ec += mmcsd_read_data(i + 0x14, 2, (int16*)&stream->Start_Addr + 1);
            ec += mmcsd_read_data(i + 0x1A, 2, &stream->Start_Addr);
            if(ec != GOODEC)
               return EOF;
            // convert stream->Start_Addr to an address
            stream->Start_Addr = cluster_to_addr(stream->Start_Addr);
            stream->Entry_Addr = i;
            // set up some permission-specific parameters if we're at a file
            if(attrib == 0x20)
               stream->File_Type = Data_File;
               if(stream->Flags & Write)
                  // delete all previous data in the file
                  stream->Bytes_Until_EOF = stream->Size = 0;
                  // if there is already space allocated, get rid of it
                  if(stream->Start_Addr >= Data_Start)
                     if(dealloc_clusters(addr_to_cluster(stream->Start_Addr)) == EOF)
                        return EOF;
               if((stream->Flags & Append) && (stream->Size != 0))
                  // set the position to the end of the file and fill the buffer with the contents of the end of the file
                  ec = fatsetpos(stream, &(stream->Size));
                     ec += mmcsd_read_data(stream->Cur_Char - STREAM_BUF_SIZE, STREAM_BUF_SIZE, stream->Buf);
                     ec += mmcsd_read_data(stream->Cur_Char - (stream->Cur_Char % STREAM_BUF_SIZE), STREAM_BUF_SIZE, stream->Buf);
#ifndef FAST_FAT
                  // fill up the read buffer for reading
                  ec = mmcsd_read_data(stream->Cur_Char, STREAM_BUF_SIZE, stream->Buf);
               if(ec != GOODEC)
                  return EOF;
               stream->File_Type = Directory;
            return GOODEC;
      // check to make sure that the next iteration will give us a contiguous cluster
      if(get_next_entry(&i) == EOF)
         return EOF;
   } while(cur_state != 0x00);
   // if we reach this point, we know that the file won't be found
   stream->Flags |= File_Not_Found;
   return EOF;
Summary: This will get a name of a file.
Param file_entry_addr: The position in memory that the file's entry is.
Param name[]: The place to put the name of the file into.
   int
      j,       // counter for loops
      k = 0,   // current character in array
      order,   // byte to hold the current long file name order
      type;    // the type of entry that was just read in
   int32 i;          // pointer for memory
   // the long file name isn't fragmented across clusters
   i = file_entry_addr;
   // check to make sure that this file has a long file name
   if(mmcsd_read_data(i - 0x15, 1, &type) != GOODEC)
      return EOF;
   if(type != 0x0F)
      // this file doesn't have a long file name
      if(get_short_file_name(i, name, type) == EOF)
         return EOF;
      return GOODEC;
   do
      // head to the previous entry
         return EOF;
      for(j = 1; j < 0x20; j += 2, k += 1)
         if(j == 11)
            j = 14;
         else if(j == 26)
            j = 28;
         if(mmcsd_read_data(j + i, 1, &(name[k])) != GOODEC)
            return EOF;
      // now that that's done with, get the entry's order
      if(mmcsd_read_data(i, 1, &order) != GOODEC)
         return EOF;
   } while(!(order & 0x40));  // the last entry will be 0b01xxxxxx
   // end the name[] buffer with a \0
   name[k] = '\0';
   return GOODEC;
signed int set_file_name(int32 parent_dir_addr, int32 entry_addr, char name[])
Summary: Creates both a short and long file name at the first free entry in a directory.
Param parent_dir_addr: The address of the parent directory to create the short file name in.
Param entry_addr: The address the function put the short file name entry.
Param name: The full file name.
   char sname[12];   // place to hold the short file name
   signed int name_pos = 0;   // the current parse position of name[]
   int
      chksum,               // the long file name checksum
      entire_entry[0x20],   // the entire entry to put write onto the media
      entry_pos,            // the current position inside of entire_entry
      long_entry = 1;       // the current long entry number we're on
   // check for invalid characters
   if(check_invalid_char(name) == EOF)
      return EOF;
   // make a short file name of this
   if(make_short_file_name(parent_dir_addr, name, sname) == EOF)
      return EOF;
   // get a checksum for the long file name entries
   chksum = long_name_chksum(sname);
   // start writing the long file name
   // zero out entry[]
   for(entry_pos = 0; entry_pos < 0x20; entry_pos += 1)
      entire_entry[entry_pos] = 0;
   i = parent_dir_addr;
   if(get_next_free_entry(&i) == EOF)
      return EOF;
   // 0x0F signifies an file entry
   entire_entry[11] = 0x0F;
   // since we're working in reverse, write the final long name entry
   name_pos = strlen(name);
   name_pos %= 13;
   if(name_pos != 0)
      // add 1 to account for the \0 terminator
      name_pos += 1;
      fill_entry(entire_entry, 0xFF, name_pos);
   // start writing the long file name entries
   // figure out how many entries this name will take up
   long_entry = (name_pos / 13) + 1;
   if(name_pos % 13 == 0)
      long_entry -= 1;
   // set the bit to signify this is the final entry
   long_entry |= 0x40;
   while(name_pos >= 0)
      entry_pos = name_pos % 13;
      if(entry_pos < 5)
         entire_entry[(entry_pos << 1) + 1] = name[name_pos];
      else if(entry_pos < 11)
         entire_entry[(entry_pos << 1) + 4] = name[name_pos];
         entire_entry[(entry_pos << 1) + 6] = name[name_pos];
      if((entry_pos == 0)
         && (name_pos != strlen (name)))
         entire_entry[0] = long_entry;
         // clear off the bits at positions 6 and 7 if the most recent entry was the final one.
         if(name_pos != 0)
            long_entry &= 0x3F;
         long_entry -= 1;
         entire_entry[13] = chksum;
            return EOF;
            return EOF;
         fill_entry(entire_entry, 0x00, 0);
      name_pos -= 1;
   // write the short file name to the entry
   if(mmcsd_write_data(i, 11, sname) != GOODEC)
      return EOF;
   // set the new entry addr
   *entry_addr = i;
   return GOODEC;
Summary: Reads a file's short file name, puts all the characters into lower case, and puts it into a buffer.
Param file_entry_addr: Where the file's entry address is located.
Param sname: The buffer to put the short file name.
   int
      buf,
      i,
      j = 0;
   for(i = 0; i < 11; i += 1)
         return EOF;
      if(buf != ' ')
         sname[j] = tolower(buf);
         j += 1;
   // tack on a null terminator
   sname[j] = '\0';
   //printf("\r\n%s, %u\r\n",sname, strlen(sname));
   if(type != 0x10 && strlen(sname) > 3)
      j = strlen(sname);
      for(i=j; i > j-3; --i)
         sname[i] = sname[i-1];
      sname[i] = '.';
   sname[j+1] = '\0';
   return GOODEC;
 int
   buf,
   i,
   j = 0;
       return EOF;
       if(buf != ' ')
   sname[j] = '\0';
   return GOODEC;
Summary: Creates a unique short file name in a directory.
Param fname: The full file name.
Param sname: Character array that will hold the short file name upon function completion.
   char
      val[12] = "           ",
      cur_fname[12] = "           ",
      cur_fnum[7] = "      ";
   int
      buf,
      ext_pos,
      fname_parse_pos = 0,
      val_parse_pos = 0;
   int32
      fnum = 0,
      i;
   // figure out where the extension position is
   ext_pos = strchr(fname, '.');
   // check to see if this file has an extension
   if(ext_pos == 0)
      while((val_parse_pos < 8) && (fname[fname_parse_pos] != '\0'))
         val[val_parse_pos] = toupper(fname[fname_parse_pos]);
         val_parse_pos += 1;
         // we can't have a '.' or ' ' in the short name
         while((fname[fname_parse_pos] == '.') || (fname[fname_parse_pos] == ' '))
      ext_pos -= fname - 1;
      while((val_parse_pos < 11) && (fname[fname_parse_pos] != '\0'))
         val_parse_pos += 1;
         // check to see if it's time to skip val_parse_pos ahead to the file extension
         if(fname_parse_pos == ext_pos)
            val_parse_pos = 8;
         // check to see if it's time to skip name_parse_pos ahead to the file extension
         else if(val_parse_pos == 8)
            fname_parse_pos = ext_pos;
   // now that we've got the short file name, we need to make it unique
   if(mmcsd_read_data(i + 0x0B, 1, &buf) != GOODEC)
      return EOF;
   // keep reading until we hit empty space
   while(buf != 0x00)
      // check to see if this is a short file name entry
      if((buf == 0x20) || (buf == 0x10))
         // read in the short file name that we're currently pointing at
         if(mmcsd_read_data(i, 11, cur_fname) != GOODEC)
            return EOF;
         cur_fname[11] = '\0';
         // strcmp will return a 0 if the file name we're currently pointing at and the file name that we created above are the same
         if(strcmp(cur_fname, val) == 0)
            // we now need to create a unique file name
            //  increment the unique file number by one
            fnum += 1;
            // convert the unique file number to a string
            sprintf(cur_fnum, "%u", fnum);
            // put the unique file number, along with a '~' into our short file name
            fname_parse_pos = 0;
            // find out the last posiiton of a space
            val_parse_pos = strchr(val, ' ');
            if(val_parse_pos == 0)
               // if there isn't a space, then we're going to have to put the ~x at the end of the short name
               val_parse_pos = 7 - strlen(cur_fnum);
               // if there is a space, then put the ~x there
               val_parse_pos -= val + 2;
            // make some room for extra digits
            buf = 10;
            while(fnum >= buf)
               val_parse_pos -= 1;
               buf *= 10;
            // write in the ~
            val[val_parse_pos] = '~';
            // write in the number
            val_parse_pos += 1;
            while(cur_fnum[fname_parse_pos] != '\0')
               val[val_parse_pos] = cur_fnum[fname_parse_pos];
               val_parse_pos += 1;
            // start the search over again to see if that unique file name/number combination is still taken up
      // head to the next entry
         // we're going to have to allocate another cluster
         if(alloc_clusters(addr_to_cluster(i), &i) == EOF)
            return EOF;
         return EOF;
   // copy the short name into the input buffer
   for(i = 0; i < 12; i += 1)
      sname[i] = val[i];
   return GOODEC;
int long_name_chksum (int* FcbName)
Summary: Returns an unsigned byte checksum computed on an unsigned byte
          array. The array must be 11 bytes long and is assumed to contain
          a name stored in the format of a MS-DOS directory entry.
Param: Pointer to an unsigned byte array assumed to be 11 bytes long.
Returns: Sum An 8-bit unsigned checksum of the array pointed to by pFcbName.
   int
      FcbNameLen,
      Sum = 0;
   for(FcbNameLen = 11; FcbNameLen != 0; FcbNameLen -= 1)
      // The operation is an unsigned char rotate right
      Sum = ((Sum & 1) ? 0x80 : 0) + (Sum >> 1) + *pFcbName++;
   return Sum;
Summary: Checks the filename for any invalid characters.
Param: The name of the file to check.
Returns: EOF if an invalid character was found, GOODEC otherwise.
   int fname_pos;
   for(fname_pos = 0; (fname[fname_pos] != '\0') && (fname_pos < MAX_FILE_NAME_LENGTH); fname_pos += 1)
      if(isamoung(fname[fname_pos], "\\/:*?\"<>|"))
         return EOF;
   return GOODEC;
			Neo2a
				| Main code |
				 Posted: Wed Aug 22, 2012 2:49 am     |
				The main code is this
based on the example in ccsc
#include <fat16 proba.h>
//#use rs232(UART1,baud=9600,parity=N,bits=8,stream=RS232)
#byte PLLDIV = 0x746   // bits 8--0 = Pll div = 0x1e
#byte CLKDIV = 0x744   // bits 7--6 = Pll post = 0  // bits 4--0 = Pll Pre = 0
#byte SPI2CON1 = 0x262
#include "\mmcsd.c"
#include "\fat.c"
#include <stdlib.h> // for atoi32
#define COMMAND_SIZE 10
#define NUM_COMMANDS 11
char g_CWD[200] = "/"; //current working directory
char commands[NUM_COMMANDS][COMMAND_SIZE]=
   "del",      //option1=filename.  delete file.
   "make",     //option1=filename.  create an empty file, give error if file already exists
   "append",   //option1=filename, option2=string.  append string to end of file
   "cd",    //option1=new cwd.  change working directory.  / is root.
   "dir",    //show files in directory
   "cat",    //option1=filename.  display full contents in ascii
   "tail",  //option1=filename.  display the last 20 lines of file.
   "mkdir", //option1=dir.  create directory.  see 'cd' for rules on dir
   "rmdir",  //option1=dir.  remove directory.  see 'cd' for rules on dir.
   "format",   // option1=media size in bytes. formats the media.
   "help"   // help!
Summary: Finds a command from the global list of commands.
Param: A pointer to the command string.
Returns: The command number if the command is found in the command list.
         0xFF if the command isn't found
int FindCommand(char *cmd)
   char buf[COMMAND_SIZE];
   int i;
   for (i=0; i<NUM_COMMANDS; i++)
      strcpy(buf, &commands[i][0]);
      if (stricmp(buf, cmd)==0)
         return(i);
   return(0xFF);
Summary: Displays the current working directory.
Param: None.
Returns: None.
void DisplayPrompt(void)
   printf("\r\n\n%s> ", g_CWD);
Returns: None.
void DeleteFile(char *fileName)
   printf("\r\nDeleting '%s': ", fileName);
   if(rm_file(fileName) != GOODEC)
      printf("Error deleting file");
      return;
   printf("OK");
Returns: None.
Example Usage: \> make "Log.txt"
void MakeFile(char *fileName)
   printf("\r\nMaking file '%s': ", fileName);
   if(mk_file(fileName) != GOODEC)
      printf("Error creating file");
      return;
   printf("OK");
Summary: Append a string to a file.
Param: The full path of the file to append to.
Param: A pointer to a string to append to the file.
Returns: None.
Example Usage: \> append "Log.txt" "This will be appended to the end of Log.txt"
Note: A "\r\n" will be appended after the appendString.
void AppendFile(char *fileName, char *appendString)
   FILE stream;
   printf("\r\nAppending '%s' to '%s': ", appendString, fileName);
   if(fatopen(fileName, "a", &stream) != GOODEC)
      printf("Error opening file");
      return;
   fatputs(appendString, &stream);
   fatputs("\r\n", &stream);
   if(fatclose(&stream) != GOODEC)
      printf("Error closing file");
      return;
   printf("OK");
Summary: Change the working directory.
Param: The new working directory to switch to.
Returns: None.
Example Usage: \> cd ftp/     -> /ftp/
               \ftp\> cd files/  -> /ftp/files/
               \ftp\files> cd..  -> /ftp/
               \ftp\> cd ..      -> /
               \> cd /ftp/files/ -> /ftp/files/
Note: Changing the directory to .. will go up a directory.
void ChangeDirectory(char *newCWD)
   FILE stream;
   //append a / to the end of the filename if it doesn't exist
   //making an assumption here that newCWD can hold 1 more character
   if (newCWD[strlen(newCWD)-1] != '/')
     strcat(newCWD, "/");
   if((strstr(newCWD, "../") != 0) && (strcmp(g_CWD, "/") != 0))
      g_CWD[strlen(g_CWD) - 1] = '\0';
      g_CWD[strrchr(g_CWD, '/') - g_CWD + 1] = '\0';
      if(fatopen(newCWD, "r", &stream) != GOODEC)
         printf("\r\nError changing directory");
         return;
      strcpy(g_CWD, newCWD);
Summary: Display the contents of the working directory.
Param: The full path of the directory contents to display.
Returns: None.
Example Usage: /> dir
void DisplayDirectory(char *dir)
   disp_folder_contents(dir);
Summary: Create a directory.
Returns: None.
Example Usage: /> mkdir "Backlog"
void MakeDirectory(char *dir)
   if (dir[strlen(dir)-1] != '/')
     strcat(dir, "/");
   printf("\r\nMaking directory '%s': ", dir);
   if(mk_dir(dir) != GOODEC)
      printf("Error creating directory");
      return;
   printf("OK");
Summary: Remove a directory.
Param: The full path of the directory to remove.
Returns: None.
Example Usage: /> rmdir "Backlog"
Note: The directory needs to be empty in order for this command to work.
void RemoveDirectory(char *dir)
   printf("\r\nRemoving directory '%s': ", dir);
     strcat(dir, "/");
   if(rm_dir(dir) != GOODEC)
      printf("Error removing directory");
      return;
   printf("OK");
#define CAT_FROM_START  FALSE
#define CAT_FROM_END    TRUE
Summary: Prints either all of or the last 80 characters in a file.
Param: The full path of the file to print off.
Param: If true, this function will print off the last 80 characters in the file.
       If false, this funciton will print off the entire file.
Returns: None.
Example Usage: /> cat "Logs.txt" (this will display the entire file)
Example Usage: /> tail "Logs.txt" (this will display the last 80 characters in the file)
void PrintFile(char *fileName, int1 startFromEnd)
   FILE stream;
   if(fatopen(fileName, "r", &stream) != GOODEC)
      printf("\r\nError opening file");
      return;
   printf("\r\n");
   if(startFromEnd)
      fatseek(&stream, 80, SEEK_END);
   fatprintf(&stream);
   fatclose(&stream);
Summary: Formats the media to a specified size.
Param: The size of the media, in kB, in string form.
Returns: None.
Example Usage: /> format 524288 (format a 512MB card)
void FormatMedia(char *mediaSize)
   int32 size;
   size = atoi32(mediaSize);
   printf("\r\nFormatting media (size=%LU): ", size);
   if(format(size) != GOODEC)
      printf("Error formatting media");
      return;
   printf("OK");
Summary: Shows a help prompt.
Param: None.
Returns: None.
Example Usage: /> help
void ShowHelp()
   printf("\r\nFAT Shell Help");
   printf("\r\n del filename --- Deletes the file");
   printf("\r\n make filename --- Creates an empty file");
   printf("\r\n append filename string --- Appends string to the end of the file");
   printf("\r\n cd dir --- Change the working directory");
   printf("\r\n dir --- Shows the contents of the directory");
   printf("\r\n cat filename --- Displays content of file");
   printf("\r\n tail filename --- Displays the last 80 characters of file");
   printf("\r\n mkdir dir --- Create a directory");
   printf("\r\n rmdir dir --- Deletes the directory");
   printf("\r\n format size --- Format card.  (Example: 'format 5524288' formats a 512MB card)");
   printf("\r\n help\tYou are here");
   printf("\r\n\n Put a parameter in quotes if it has spaces");
char * GetCMD(char *in)
   char tokens[]=" \r\n";
   return(strtok(in,tokens));
char * GetOption(char *in)
   char tokensSpace[]=" \r\n";
   char tokensQuote[]="\"\r\n";
   //trim leading spaces
   while (*in==' ')
      in++;
   //if first char is a quote, then end token on a quote.  ELSE end token on a space
   if (*in == '\"')
      return(strtok(in,tokensQuote));
      return(strtok(in,tokensSpace));
   //PLL setting for 32M and SPI CLK settings for hardware SPI2
   PLLDIV=30;
   CLKDIV=128;
   SPI2CON1=60;
   set_tris_g (80);
   output_high(PIN_C4);              // Disable Serial Flash module
   output_high(PIN_G12);             // Disable MP3 module
   output_low(PIN_D7);               // LCD backlight off
   setup_spi( FALSE );               //Kill hardware SPI
   setup_spi2( FALSE );              //Kill hardware SPI2
   printf("Program Started!");
   delay_ms(2000);
   char buffer[255];
   char opt_buffer[255];
   char *cmd, *option1, *option2;
   int i;   // pointer to the buffer
   // initialize the FAT
   //  keep in mind that this will automagically initialize the media
   i = fat_init();
   if (i)
      printf("\r\n\nERROR INITIALIZING FAT\r\n\n");
   // main loop
      i = 0;
      DisplayPrompt();
      do
         buffer[i] = getch();
         // check for a backspace
         if(buffer[i] != 8)
            printf("%c", buffer[i]);
            i++;
         else if(i > 0)
            // delete the last character
            i--;
            putc(8);
            putc(' ');
            putc(8);
         buffer[i] = '\0';
      } while(buffer[i - 1] != '\r');
      // parse the command and options
      cmd = GetCMD(buffer);
      option1 = GetOption(cmd + strlen(cmd) + 1);
      option2 = GetOption(option1 + strlen(option1) + 1);
      //if option1 starts with a '/', that means the file in the option includes
      //the full path to the file.  if the file doesn't start with a '/', the
      //current working directory must be added.
      if (option1 && (option1[0]=='/'))
         //option1 is a full path
         strcpy(opt_buffer, option1);
      else if (option1)
         // tack on the current working directory to option1
         strcpy(opt_buffer, g_CWD);
         strcat(opt_buffer, option1);
      if (cmd)
         switch(FindCommand(cmd))
            case 0:  //del
               DeleteFile(opt_buffer);
            case 1:  //make
               MakeFile(opt_buffer);
            case 2:  //append
               AppendFile(opt_buffer, option2);
            case 3:  //change directory
               ChangeDirectory(opt_buffer);
            case 4:  //show directory contents
               DisplayDirectory(g_CWD);
            case 5:  //cat, display file
               PrintFile(opt_buffer, CAT_FROM_START);
            case 6:  //tail, display last 80 charachters
               PrintFile(opt_buffer, CAT_FROM_END);
            case 7: //mkdir, make a directory
               MakeDirectory(opt_buffer);
            case 8: //rmdir, make a directory
               RemoveDirectory(opt_buffer);
            case 9: //format, format the card
               FormatMedia(option1);
            case 10: //help, display help
               ShowHelp();
            default:
               printf("\r\nUnkown Command '%s'", cmd);
The header file in the fat16 proba.h
#include <33FJ256GP710A.h>
#device ICD=TRUE
#device PASS_STRINGS = IN_RAM
#device ADC=12
#FUSES WDT                    //Watch Dog Timer
#FUSES NOBSS                    //No boot segment
#FUSES NOOSCIO                    //OSC2 is general purpose output
#FUSES PR_PLL                     //Pimary oscillator
#FUSES XT
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PUT128                   //Power On Reset Timer value 128ms
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NORSS                    //No secure segment RAM
#FUSES NOSSS                    //No secure segment
#FUSES NOWRTSS                  //Secure segment not write protected
#FUSES NORBS                    //No Boot RAM defined
#FUSES NOJTAG                   //JTAG disabled
#use delay(clock=32000000)
#use fixed_IO(E_outputs = PIN_E0,PIN_E0,PIN_E1,PIN_E1,PIN_E2,PIN_E2)
#use rs232(baud=9600,xmit=PIN_F5,rcv=PIN_F4,parity=N,bits=8,stream=USB,errors) |
I hope somebody will help me.
Thax
Steve |
