Newbie stupid question - help with compiler errors
flavinm
PostPosted: Mon Aug 13, 2012 6:51 am     Reply with quote
I am just now getting back in to programming after 20 years and I was starting a practice project. I went through the new project wizard and that went fine but when I try to compile with no changes to the generated files I get a bunch of errors like First declaration of LCD_PIN_MAP and identifier is already used in this scope. I have looked at it for 2 days and since its generated by the program I'm not sure where to look. Thanks
typedef struct
{                            // This structure is overlayed
   BOOLEAN enable;           // on to an I/O port to gain
   BOOLEAN rs;               // access to the LCD pins.
   BOOLEAN rw;               // The bits are allocated from
   BOOLEAN unused;           // low order up.  ENABLE will
   int     data : 4;         // be LSB pin of that port.
  #if defined(__PCD__)       // The port used will be LCD_DATA_PORT.
   int    reserved: 8;
} LCD_PIN_MAP;
PostPosted: Mon Aug 13, 2012 12:36 pm     Reply with quote
Read these threads which discuss how to fix the problem:
http://www.ccsinfo.com/forum/viewtopic.php?t=42061
http://www.ccsinfo.com/forum/viewtopic.php?t=42234
http://www.ccsinfo.com/forum/viewtopic.php?t=42120
http://www.ccsinfo.com/forum/viewtopic.php?t=48041
http://www.ccsinfo.com/forum/viewtopic.php?t=42269
