Newbie stupid question - help with compiler errors
Posted: Mon Aug 13, 2012 6:51 am
I am just now getting back in to programming after 20 years and I was starting a practice project. I went through the new project wizard and that went fine but when I try to compile with no changes to the generated files I get a bunch of errors like First declaration of LCD_PIN_MAP and identifier is already used in this scope. I have looked at it for 2 days and since its generated by the program I'm not sure where to look. Thanks
typedef struct
{ // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be LSB pin of that port.
#if defined(__PCD__) // The port used will be LCD_DATA_PORT.
int reserved: 8;
} LCD_PIN_MAP;
Posted: Mon Aug 13, 2012 12:36 pm
