zork
| adc oscillating problem |
Posted: Wed Jul 25, 2012 11:51 am |
Hello friends, could anyone tell me if this is right?
#include <16F876A.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#include <lcd_flex.C>
int16 value_adc0 = 0;
char value_adc_0[6];
void read_adc0()
set_adc_channel(0);
delay_ms(10);
value_adc0 = read_adc() ;
value_adc0=((value_adc0*0.03937007874015748031496062992126)*100); //(5/254)*100
sprintf(value_adc_0,"%05lu",value_adc0);
void print_adc0()
lcd_putc(value_adc_0[2]);
lcd_putc(value_adc_0[3]);
setup_adc_ports(AN0_AN1_AN3);
setup_adc( ADC_CLOCK_DIV_8 );
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_RTCC);
lcd_init();
while(true)
lcd_putc('\f');
read_adc0();
print_adc0();
lcd_gotoxy(1,1);
delay_ms(200);
I always have problem with this code, the ADC value is always fluctuating, what's wrong? I need help, please.
Thank you |
SherpaDoug
Posted: Wed Jul 25, 2012 4:11 pm |
| Quote: | value_adc0=((value_adc0*0.03937007874015748031496062992126)*100); //(5/254)*100
Where did that number come from? 5/254 is about 0.02, nowhere near 0.039. Floating point math in the PIC is only good to a little better than 6 digits so anything beyond 0.03937008 is rather pointless.
Is there a reason you force value_adc0 * 0.03937008 THEN * 100, instead of letting the compiler precalculate 0.03937008 * 100 so the PIC only has to actually do value_adc0 * 3.937008? It consumes more CPU cycles with no benefit I can see. _________________ The search for better is endless. Instead simply find very good and get the job done. |
