tonkostz
Issues with low frequency software pwm and duty cycle |
Posted: Thu Jul 19, 2012 11:06 am |
I want to generate a PWM with frequency from 3Hz to 30Hz. Also duty cycle from 100uS to 2mS with 50uS steps. I use the following program but the lowest on time is 116 when width=1 and the step is more than 120us. For example if width=2, on time is 235uS etc. I want to vary the on time with 50uS steps - 100,150,200,250...2000.
Compiler version is 4.120.
#include <18f2431.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP,PUT,NODEBUG,BROWNOUT,NOCPD,NOWRT
#include <LCD20x4.c>
#define PWM_PIN PIN_B1
#define TIMER0_PRELOAD 153
#define LOOPCNT freq
int8 status_enter_prev,status_up_down_main,f=1,frequency;
int16 width=1,freq,duty;
void buttons_freq_up_down()
if(!input(PIN_C0) && status_enter_prev==0) //freq up
f++;
if(f>28)
f=28;
delay_ms(50);
if(!input(PIN_C3) && status_enter_prev==0) //freq down
f--;
if(f<1)
f=1;
delay_ms(50);
if(input(PIN_C0) && input(PIN_C3))
status_enter_prev=0;
while(!input(PIN_C0)) // Loop here until button released.
delay_ms(25);
while(!input(PIN_C3)) // Loop here until button released.
delay_ms(25);
void buttons_duty_up_down()
if(!input(PIN_C1) && status_up_down_main==0) //duty up
status_up_down_main=1;
//delay_ms(50);
width++;
if(width>17)
width=17;
else if(!input(PIN_C4) && status_up_down_main==0) //duty down
//delay_ms(50);
width--;
if(width<1)
width=1;
if(input(PIN_C1) && input(PIN_C4))
status_up_down_main=0;
while(!input(PIN_C1)) // Loop here until button released.
delay_ms(25);
while(!input(PIN_C4)) // Loop here until button released.
delay_ms(25);
void frequency_change()
if(f==1)
freq=2800;
frequency=3;
if(f==2)
freq=2100;
frequency=4;
if(f==3)
freq=1680;
frequency=5;
if(f==4)
freq=1380;
frequency=6;
if(f==5)
freq=1190;
frequency=7;
if(f==6)
freq=1040;
frequency=8;
if(f==7)
freq=920;
frequency=9;
if(f==8)
freq=840;
frequency=10;
if(f==9)
freq=765;
frequency=11;
if(f==10)
freq=695;
frequency=12;
if(f==11)
freq=645;
frequency=13;
if(f==12)
freq=600;
frequency=14;
if(f==13)
freq=560;
frequency=15;
if(f==14)
freq=525;
frequency=16;
if(f==15)
freq=495;
frequency=17;
if(f==16)
freq=460;
frequency=18;
if(f==17)
freq=440;
frequency=19;
if(f==18)
freq=420;
frequency=20;
if(f==19)
freq=400;
frequency=21;
if(f==20)
freq=382;
frequency=22;
if(f==21)
freq=366;
frequency=23;
if(f==22)
freq=350;
frequency=24;
if(f==23)
freq=337;
frequency=25;
if(f==24)
freq=324;
frequency=26;
if(f==25)
freq=311;
frequency=27;
if(f==26)
freq=300;
frequency=28;
if(f==27)
freq=290;
frequency=29;
if(f==28)
freq=280;
frequency=30;
void duty_change()
if(width==1)
duty=116;
if(width==2)
duty=235;
if(width==3)
duty=350;
if(width==4)
duty=465;
if(width==5)
duty=585;
if(width==6)
duty=710;
if(width==7)
duty=830;
if(width==8)
duty=950;
if(width==9)
duty=1070;
if(width==10)
duty=1200;
if(width==11)
duty=1320;
if(width==12)
duty=1450;
if(width==13)
duty=1550;
if(width==14)
duty=1670;
if(width==15)
duty=1800;
if(width==16)
duty=1920;
if(width==17)
duty=2020;
#INT_RTCC
void tick_interrupt(void);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1 | RTCC_8_BIT);
set_timer0(TIMER0_PRELOAD);
enable_interrupts(INT_RTCC);
while(true)
buttons_freq_up_down();
buttons_duty_up_down();
frequency_change();
duty_change();
lcd_gotoxy(1,3);
printf(lcd_putc,"Frequency=%u [Hz] ",frequency);
lcd_gotoxy(1,4);
printf(lcd_putc,"ON Time=%lu [uS] ",duty);
#INT_RTCC
static int16 loop = LOOPCNT;
static int16 pulse;
set_timer0(get_timer0() + TIMER0_PRELOAD);
if(--loop == 0)
loop = LOOPCNT;
pulse = width;
if(pulse)
output_high(PWM_PIN);
pulse--;
output_low(PWM_PIN);
Posted: Thu Jul 19, 2012 11:41 am |
Quote: | I want to vary the on time with 50uS steps.
It's not going to happen with a 4 MHz oscillator frequency. That gives 1 us
per instruction cycle. It takes 50 instructions of overhead just to handle
the interrupt. Your user code inside the isr will increase this even more.
Try increasing your oscillator frequency. Then you will have a chance
to make it work. |
Mike Walne
Posted: Tue Jul 24, 2012 11:14 am |
Do you have to use EXACTLY 50us steps?
Could you, for instance, use 32us or 64us?
Mike
EDIT
Seriously, you can use the hardware PWM built into the PIC.
You set up the PWM generator so that:-
(1) The PWM duty creates a mark period with the desired ON time.
(2) The timer2 interrupt operates with a period significantly greater that your maximum on time.
Use the interrupt to control the PWM:-
(a) Enable the PWM for a single period.
(b) Disable the PWM long enough to give the desired repeat period. |
