waheed
12f675 Adc |
Posted: Thu Jul 12, 2012 5:27 am |
I have a simple program to test the ADC. But when i do the simulation on proteus, it show the following msgs:
1: Effect of writing OSCAL register not modelled.
2: ADC conversion started before "wait" time has expired following previous conversion or channel change.
Here is the code:
#include<12f675.h>
#fuses NOWDT,HS,NOPROTECT,BROWNOUT,NOPUT,NOCPD,INTRC_IO
#device ADC=10
#INCLUDE <stdlib.h>
int16 adc_value,value;
setup_ADC(ADC_CLOCK_DIV_64);
setup_ADC_ports(AN0_ANALOG);
set_adc_channel(0);
while (1)
output_toggle(PIN_A5);
adc_value=read_adc();
value=5*adc_value/1024;
if (adc_value>3){output_low(PIN_A2);}
if (adc_value<3){output_low(PIN_A4);}
Joined: 01 Jul 2010 Posts: 9216 Location: Greensville,Ontario
Posted: Thu Jul 12, 2012 5:45 am |
Doesn't surprise me at all.
Proteus is KNOWN to be FULL of errors,bugs, and faulty DRCs !!
You are best to get rid of it ! remove from PC !!
Unless you want to spend 1000s of hours hacking and rewriting the Proteus 'simulator', move on, get real chips and do real world 'simulation'.
It is well known that Proteus DOES NOT WORK CORRECTLY !!
hth
jay |
Posted: Thu Jul 12, 2012 8:35 am |
The second error is 'correct' though, on the first time through the loop.
Whenever you select an ADC channel, you _must_ wait for Tacq, _before_ reading. Your code, selects the adc channel, enters the loop, toggles pin A5, and immediately read the adc. Tacq, depends on a number of factors, but from the data sheet for your chip, is just under 10uSec. The instructions you execute at 20MHz, will only take perhaps 1uSec....
Solution is to move the delay, so it gets executed the first time through the loop:
void main(void) {
set_adc_channel(0);
while (1) {
waheed
Posted: Fri Jul 13, 2012 5:15 am |
Thnx.
This did it. |
