PLL on internal clock
rikotech8
PostPosted: Sat Sep 29, 2012 1:49 am     Reply with quote
Hi!
How can I measure a clock (osc/4) frequency of my MCU? I need to do it, because I test 18F2520 (MCU)whether it reach maximum clock freq 32MHZ by PLL function and internal oscilator. Here is the code I use:
#include <18F2520.h>
#FUSES INTRC_IO,PUT,NOWDT,NOMCLR
#use delay(internal = 8M)
setup_oscillator(OSC_32MHZ|OSC_INTRC|OSC_PLL_ON);
while(true)
   output_toggle(pin_b0);
May be the output shall toggling with clock freq divided by two?
Re: PLL on internal clock
PostPosted: Sat Sep 29, 2012 2:15 am     Reply with quote
rikotech8 wrote:
Hi!
while(true)
No.
Start at the beginning. The processor executes one instruction for each four cycles of the CPU clock. So at 32MHz, the processor performs at 8MIPS.
Then the output_toggle instruction, involves two processor instructions, while the jump back though one instruction, takes two cycle times (look up jump instructions in the data sheet). So four instruction times. So the pin should take 500nSec between edges (4*125nSec), giving 1MHz out.
As a comment, the use delay statement, should match your clock. So needs to say 32MHz, not 8MHz. This won't 'matter' for the code as shown, but will cause problems with timings, RS232, etc. etc. in the future.
