How to use LDT0 Vibration Sensor Piezo Film with PIC ?
mmc01
PostPosted: Thu Jul 05, 2012 8:46 pm     Reply with quote
I want to read data from LDT0 Vibration Sensor Piezo Film. This is data sheet.
http://www.meas-spec.com/downloads/LDT_Series.pdf
I try to read data like this example
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/PiezoInfo.pdf
In this example I think it only read high or low input but when I try to read it I can't read anything from sensor. It have no 5V to trigger input high. And If I want to read vibration for build car security how to do it with PIC.
Mike Walne
PostPosted: Fri Jul 06, 2012 4:31 am     Reply with quote
Begin by having a look at the sensor output on a 'scope.
This will tell you:-
(1) Whether the sensor is working or not.
(2) What kind of a signal you're playing with.
(3) The starting point for your coding.
Mike
SherpaDoug
PostPosted: Fri Jul 06, 2012 6:26 am     Reply with quote
The Parallax example works if the sensor is used as a switch, like if you tap it with your finger. If you are looking for vibrations you must look for smaller signals. At least use a PIC A/D pin or better yet use an amplifier.
Mike is right. You need to look at the signal with a scope to see just what you are dealing with.
