Problem in Implementing X-10
alexboin
PostPosted: Fri Sep 14, 2012 8:26 am     Reply with quote
Hello friends
I want to implement x-10 on pic877a but I can not get the right answer from suggested filters in "an236" pdf !
Does anyone have an idea or interchange circuit?
rgds!
ezflyr
PostPosted: Fri Sep 14, 2012 10:02 am     Reply with quote
First of all, are you using the CCS 'C' compiler? If not, you are in the wrong
forum!
If so, CCS supplies an example program that demonstrates how to use X-10
with the compiler. This program is located in the 'examples' folder once you
install the compiler. The filename is 'ex_x10.c'.
The hardest part of using X-10 is the interface to the powerline. The easiest
way to do this is to use a commercially available powerline interface like the
X-10 TW-523. This is the interface used by the CCS example program.
John
