Problem with definition of function
Lemosek
PostPosted: Tue Jun 19, 2012 1:54 pm     Reply with quote
I write simple test code but I have error:
Function definition different from previous definition
I use similar code at gcc compiler and it works.
What I'm doing wrong at CCS ??
Best regards
R.L.
#include <18F2580.h>
#fuses HS, NOPROTECT, PUT, BROWNOUT, NOWDT, NOLVP
#use delay(clock=20M)
// wskaźnik do funkcji callback dla zdarzenia EVENT()
static void (*event_callback)(char *pBuf);
// funkcja do rejestracji funkcji zwrotnej w zdarzeniu EVENT()
void register_event_callback(void(*callback)(char *pBuf)) {
   event_callback = callback;
// Zdarzenie
void EVENT(char * rbuf) {
   if( flag ) { //if flag is active
      if( event_callback ) {
         (*event_callback)( rbuf );
void parse_uart_data( char * pBuf ) {
//jakis kod
char bufor[100];
int1 flag=0;
   // rejestracja własnej funkcji
   register_event_callback( parse_uart_data );
While(1){
    EVENT(bufor);   // zdarzenie
khalis
PostPosted: Wed Jun 20, 2012 6:32 pm     Reply with quote
Hi, i think how your define your pointer is wrong.
Yours:
[EVENT(bufor);]
Should change to:
[EVENT(bufor[n]);]
n = no of your memory address (bufor)[code][]
PostPosted: Thu Jun 21, 2012 1:30 am     Reply with quote
CCS, is stricter than most compilers about definition's. Definitions used have to match exactly. This is where things like typedef (which allow you to ensure they do match), come in very useful. So:
typedef void (*event_function)(char *);
// wska?nik do funkcji callback dla zdarzenia EVENT()
event_function event_callback = 0; //must initiliase or it won't test as false
int1 flag=0; //needs to be before use of 'flag' in EVENT
char bufor[100];
void register_event_callback(event_function callback) {
// Zdarzenie
      if(event_callback) { //This only guarantees to test 'false' if the defintion is initialised to 0
   // rejestracja w?asnej funkcji
   While(1){
No idea if the code that results is right, but it should be. Smile
It does correctly put the address of parse_uart_data into the 'event_callback' variable, and calls it.
Had to also move the 'flag' definition to before where it is used, and make sure that 'event_callback' is initilised to zero, or it isn't guaranteed to test as false.
PostPosted: Thu Jun 21, 2012 2:31 am     Reply with quote
Yours:
[EVENT(bufor);]
Should change to:
[EVENT(bufor[n]);]
No. The name of an array, is a 'shortcut' for it's address in memory. So 'bufor', is the same as &bufor[0] - the address of the first element in the array. His function want's to receive the address of the array (hence the declaration says it expects a pointer - the '*'), and the function it then calls also expects a pointer (char *). This part is OK.
The problem is with CCS being 'picky' about how you declare a function pointer, and pass this to a function. Smile
Lemosek
PostPosted: Thu Jun 21, 2012 9:49 am     Reply with quote
dear Ttelmah thank You for Your answer and help Smile now is ok.
Best regards
R.L.
