How to read duty cycle with PIC ?
mmc01
PostPosted: Sun Jun 03, 2012 2:51 am     Reply with quote
I want to read duty cycle with PIC. I try to use frequency counter code to read duty cycle but I don't know how to use it. This is my code
Is this true or false to read and calculate duty cycle.
#include <16F648A.h>
#fuses XT,PUT,BROWNOUT,MCLR,NOWDT,NOPROTECT,NOLVP
#define  TxD         PIN_B2
#define  RxD         PIN_B1
#use rs232(baud=9600, xmit=TxD,rcv=RxD)
float time1,time2;
BOOLEAN hook_cpp1, HookRise;
#int_ccp1
void capture_isr()
   if(HookRise)
    time1 = get_timer1();
    HookRise = FALSE;
    printf("X");
    time2 = get_timer1();
    HookRise = TRUE;
    hook_cpp1 = FALSE;                          //done
    printf("Y\r\n");
void InitialChip(void)
   setup_comparator(NC_NC_NC_NC);               //Input Digital
   set_tris_a(0B11111110);
   set_tris_b(0B11111111);
float T;
   InitialChip();
   printf("Frequency Counter\r\n");
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      // Setup timer 1
      HookRise=TRUE;
      hook_cpp1=TRUE;
      setup_ccp1(CCP_CAPTURE_RE);
      enable_interrupts(INT_CCP1);              // Enable interrupt CCP1
      enable_interrupts(GLOBAL);                // All interrupts ON
      set_timer1(0);
      while(hook_cpp1==TRUE);
      setup_ccp1(CCP_OFF);
      disable_interrupts (GLOBAL);
      T = (time2-time1)*8*1000*0.000000001;;                // Td=cycle*(4/fosc)*PR
      printf("Time1 = %f\r\n",time1);
      printf("Time2 = %f\r\n",time2);
      printf("Time = %f\r\n",time2-time1);
      float t_all;
      t_all = time1/(time1+time2);
      printf("t_all = %f\r\n",t_all);
      //printf("Duty cycle = %f\r\n",time1/(time1+time2));
      printf("Frequency:%f Hz   %9.3e ms\r\n",1/T,T);
The results of this code is.
time1 = 73.00
time2 = 198.00
time2-time1 = 125.00
time1/(time1+time2) = 0.26
Frequency:1000.00 Hz 9.999E-04 ms
time1 = 78.00
time2 = 203.00
time1/(time1+time2) = 0.27
How to read duty cycle?
PostPosted: Sun Jun 03, 2012 5:28 am     Reply with quote
hmm... you could just grab the example that CCS supplies in the examples folder.....
or...
search the 'code library' or this forum for 'measuring pulse width' for complete code
PostPosted: Sun Jun 03, 2012 7:11 am     Reply with quote
And, as a comment, you have 'no hope', with the printf's there. Even if the UART buffer is empty, over 1mSec 'jammed' in the interrupt handler in the second case, waiting for the data to send. Invalidates everything.
As it stands though, the interrupt is always triggering on the rising edges, so all you are measuring is subsequent rising edge times, not the pulse width/duty cycle...
mmc01
PostPosted: Fri Jun 08, 2012 1:11 am     Reply with quote
or...
Thanks... Idea
